February 04, 2026, 07:16:46 PM *
Author Topic: Alternator Brushes  (Read 1331 times)
Bone
« on: April 16, 2012, 11:12:34 AM »
White Flag is waving, Help!
My 98 Tourer has 95k miles now so I pulled the Alternator knowing the brushes are over due. So far the job has been OK but installing the new brushes copper tail has stopped my progress. I can't thread the things through the holder. Does the holder come out of the plate it's installed ? That would help I'm trying to fish through and I'm not close to getting one started.
Thanks for any tips I'm sure the dealer doesn't use my method.
« Reply #1 on: April 16, 2012, 11:29:58 AM »
Just tin the tips of the copper leads with solder and make sure its really thin at the tip......it will thread in there like butter
« Last Edit: April 16, 2012, 11:44:46 AM by Chrisj CMA » Logged
Bone
« Reply #2 on: April 16, 2012, 11:59:17 AM »
Thanks ChrisJ I got them both threaded in place. I had them tined with no luck. I think walking to the house and back did the trick Smiley
Now if my solder skills are sufficient I'm close to install.
Brian
Monroe, NC
« Reply #3 on: April 17, 2012, 07:09:53 PM »
Yep, sometimes walking away for a while clears your mind for that second look. I hope your skills pay off for you.
Bone
« Reply #4 on: April 18, 2012, 04:00:24 AM »
Soldering the tails was easy. The alternator install took 5 minutes. Remembering the removal I did the tilting to the rear with the alternator and it went in the first try.
I used the article in shoptalk by Ratdog he covered all of the possible problems and made the job a success for my first attempt.
