February 04, 2026, 07:16:48 PM *
Author Topic: side stand warning light  (Read 1313 times)
Jruby38
Oxford Mass.
« on: April 16, 2012, 05:01:36 PM »
I replaced the side stand switch trying to get the warning light in the tach to work again, no luck.  It may be a burnt bulb, has anyone had had the same problem. I dont see any listing for the bulb, the rest of the warning lights work fine.
Brian
Monroe, NC
« Reply #1 on: April 16, 2012, 05:11:28 PM »
I assume the bike is running fine for you and that if you drop in gear with the kick stand down the motor stops? Have you checked for voltage on the wire going to the bulb?
Jruby38
Oxford Mass.
« Reply #2 on: April 16, 2012, 05:42:58 PM »
No, I did not check for voltage, I will.
john
tyler texas
« Reply #3 on: April 17, 2012, 05:55:09 PM »
  www.superbrightleds.com              cooldude
vrcc # 19002
