February 04, 2026, 07:16:49 PM *
Author Topic: Did the De-Smog  (Read 1483 times)
Bambam650
Cincinnati, Ohio
« on: April 17, 2012, 10:22:16 AM »
I have a 1997 Black Standard and just finished up de-smogging her over the weekend.  I know there are already lots of threads on this topic, so I'll keep it brief and just share some thoughts and experiences with the process.  I have (I think) above average mechanical skills and would say the process is not really hard, but it is very tedious.  As others have noted, sometimes you need to just walk away from the project for a little while and get your wits about you again.
One of the challenges I ran into was loosening the forward bolt on the left side check valve case.  What genius thought of putting the bolt directly under the cross member between the carbs and then putting locktight on it?  The only thing I could get on the bolt was a 10mm box end wrench, but then I couldn’t get enough leverage to crack the bolt.  I tried using a swivel and a crows foot adapter but neither would fit.  I was finally able to get a small hammer down in there to tap on the wrench enough to break the bolt free.  If anyone knows of a trick for getting this bolt out it would sure be nice to know it.
Another challenge was finding the 14mm freeze plugs to plug the four air exhaust ports.  I ended up finding some 9/16” aluminum ones at a local auto parts store, but had to file the circumference down a little bit to get them to tap in properly.  I strongly suggest you source these before you start.
The last thing (which is a very common problem) is getting the airbox boots to fit down over the carb flanges.  Actually, this didn’t fight me too much but why Honda didn’t just make the flanges a little longer is beyond me.  I would definitely modify the connection if I had to do this more often.
The good news is all of the chirping, and popping and burbling on decel is gone.  I should have done this mod a long time ago.  And besides, the fat lady can always afford to lose a little weight.
« Last Edit: April 17, 2012, 10:24:34 AM by Bambam650 » Logged
1997 Standard (Black) original owner, bought new in August 1996
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: April 17, 2012, 11:30:58 AM »
Always feels good to spend a little time & TLC with yer lady...  I felt the same way, after desmogging mine...  Shoulda done years ago  Wink
Black Dog
Don't you know...
bikerboy1951
Grand Forks, ND
« Reply #2 on: April 17, 2012, 12:08:30 PM »
Go to your local auto parts store and find or order a radiator hose removal tool.  It has a screwdriver handle and the end ends in a point and is bent at a 45 degree angle.  You run it around the frond and back of each boot and they slip right on.  It takes me about 15 minutes and they are all on as they are supposed to be.
Brad
BradValk48237
Oak Park, MI
« Reply #3 on: April 17, 2012, 12:26:01 PM »
Just did mine... same issues...
Luckily a Member here sent me his extra 14 mm plugs.....
Brad.... where did you order them from for other members in the future??????
Brad...... in MI
