March 30, 2026, 10:57:18 PM *
Author Topic: Valk Key Question  (Read 1817 times)
indybobm
Franklin, Indiana VRCC # 5258
« on: April 17, 2012, 03:06:28 PM »
Time for my Stupid Question of the Day. When the ignition is turned on, should you be able to remove the key? Just noticed that I can and am not sure if it is correct.
So many roads, so little time
VRCC # 5258
Fritz The Cat
« Reply #1 on: April 17, 2012, 03:20:26 PM »
No sir, mine comes out only when the ignition is off.
BonS
Blue Springs, MO
« Reply #2 on: April 17, 2012, 03:25:58 PM »
If it could come out when the ignition is on then it might be jarred out somewhere on a ride. Or maybe bumped out by your knee. Bad end to a good ride!
indybobm
« Reply #3 on: April 17, 2012, 03:33:37 PM »
Guess I will look into getting another ignition switch. One more key to keep track of. I can take the key out of the gas cap also when I open it. Cannot remember if that is normal.
VRCC # 5258
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
« Reply #4 on: April 17, 2012, 03:50:04 PM »
Not normal. If it's coming out of the tank cover too... common denominator is the key... get another key made based on the key code with a dealer... Won't help making it from the existing key since it appears to be worn.  Never heard of the key coming out of both before.
Patriot Guard Riders
indybobm
« Reply #5 on: April 17, 2012, 03:57:06 PM »
Where do you find the key code? Is it on the key or the lock. I have two Honda keys without any numbers.
VRCC # 5258
« Reply #6 on: April 17, 2012, 04:07:56 PM »
IF
I remember correctly a Honda dealer can look up your key from the VIN#
Do not get a key and take it home. Take the bike to the dealer so you can try the key there.
« Reply #7 on: April 17, 2012, 04:11:33 PM »
It's not likely the switch.  Most likely it's a very worn key or a poorly made copy (not in that order).
indybobm
« Reply #8 on: April 17, 2012, 04:39:06 PM »
Thanks for the help. I kind of thought it might be the key. I have two copies that seem to want to stay in the switch when it is on but they come out also.
VRCC # 5258
« Reply #9 on: April 17, 2012, 04:43:22 PM »
I agree on the worn key diagnosis.  Smiley
My rides:
indybobm
« Reply #10 on: April 19, 2012, 02:42:46 PM »
IF
Went to Dreyer Honda (oldest Honda dealer in the country) and they told me they cannot look it up by the VIN. What I found is that there are two easy ways to find your key code.
The 1st is to remove the the chrome cover from the ignition switch. Then remove the two star screws that hold the switch to the engine mount plate. The code is on the bottom of the die cast part of the switch.
The 2nd way is the easiest. Open the gas cap and get the code from the bottom of the gas cap. This will be the same number that is on the bottom of the ignition switch. It will probably be something like 8ECAxx or 8ECBxx where xx is two numbers. The dealer needs the A or B and the two numbers.
He can then cut you a new key.
VRCC # 5258
Jess Tolbirt
White Bluff, Tn.
« Reply #11 on: April 19, 2012, 02:55:00 PM »
i think some one may have modified the switch and cover lock...try any other key you have and see if it will turn on the switch,,like a master key or your car key...
Valkyrie member # 23084
WamegoRob
Wamego, KS
« Reply #12 on: April 19, 2012, 02:56:08 PM »
Thanks!  This is good info to know.
« Reply #13 on: April 19, 2012, 03:00:27 PM »
IF
 cooldude cooldude cooldude
« Reply #14 on: April 19, 2012, 05:20:40 PM »
Indybobm thanks for doing the research, good stuff. Let us know how it all turns out!  Roll Eyes
My rides:
« Reply #15 on: April 19, 2012, 07:21:52 PM »
Out of curiosity I looked under the gas cap and there isn't any numbers there even close to what my numbered key has. Nothing that looks like the 8ECAxx or 8ECBxx either. Things that make you go hmmmm.....
« Reply #16 on: April 19, 2012, 07:42:57 PM »
There are two numbers under there.  The one on the underside of the actual cap, directly where the tip of the key would point if it passed through, is the one that matters.  The one on the hinge doesn't.
The low order three characters of the one on the cap match the number imprinted on my key.
Lyn-Del
Houston area
« Reply #17 on: April 20, 2012, 04:13:48 AM »
You can also take the worn key to a LOCKSMITH, not just a place with a key machine, and they can cut you a new key by reading the old one.  I don't mean making a duplicate, but cutting a key as if they had the code number.
And many locksmiths can cut keys cheaper and more accurately than a lot of dealers can.
If you end up replacing the ignition, you can have a key made with one side cut for the ignition and one for the gas cap.  One key to carry, and if you mark it well, you'll soon be able to use it without thinking which side is which.
alph
Eau Claire, WI.
« Reply #18 on: April 20, 2012, 04:19:46 AM »
is that a bad thing?  often when i'm getting gas i would like to be able to leave the cycle in the "on" position, kill the engine with the kill switch, then be able to open the fuel cap, that way i don't have to restart my GPS, miss a song on the radio, etc.....  but you have to remove the key from the ignition switch to open the gas cap.....
MacDragon
Middleton, Mass.
« Reply #19 on: April 20, 2012, 04:41:29 AM »
Not if you have a second key on you...
« Reply #20 on: April 20, 2012, 06:19:31 AM »
Right Mac.  I always keep a key in my wallet.  I need my Credit Card anyways at the pump, so I just use that key.  AND, if you lock your keys in the trunk, you don't have to call a locksmith.  Don't ask how I know...   crazy2  uglystupid2
Hay  Cool
« Reply #21 on: April 20, 2012, 06:42:20 AM »
Turn the key counter-clockwise to the accessory position.  You should then be able to remove the key to unlock the gas cap while listening to your tunes.
Hasn't your GPS a battery backup?
« Reply #22 on: April 20, 2012, 09:06:21 AM »
Aha...give that man another sardine. Right again.  cooldude  Plus, this time I used a magnifying glass for which I got enough smartass remarks from my wife....   Grin
WamegoRob
Wamego, KS
« Reply #23 on: April 20, 2012, 09:57:27 AM »
Thanks a lot Willow...I just broke my key off trying to find the 'accessory' position  Embarrassed
« Reply #24 on: April 20, 2012, 10:08:33 AM »
Oops!   ???  Alph rides an Interstate.  Grin
Red Diamond
Beaumont, Texas
« Reply #25 on: April 20, 2012, 07:57:55 PM »
Thanks Willow, made me go to the garage to try that counter clockwise trick. My key wouldn't come out in any position. '99 I/S, code was there, though barely visible.
alph
Eau Claire, WI.
« Reply #26 on: April 20, 2012, 11:48:36 PM »
i'll have to go out and try that myself.  thanks for the info.
wiggydotcom
Yorkville, Illinois
« Reply #27 on: April 21, 2012, 04:30:54 AM »
Hmmmm. On my I/S, I found the accessory position, but the key wouldn't come out when turned to it. Oh well.
VRCC #10177
VRCCDS #239
