November 24, 2025, 03:10:56 AM *
Author Topic: Who makes this and what is it called?  (Read 1133 times)
F6BANGER
Albuquerque NM
« on: April 21, 2012, 11:52:46 AM »
Its in the trunk of my Interstate and its not letting the right brake light work. It doesnt have a brand name on it. Some type of tail light module. By the arrows, it looks like it was made 12/97
« Last Edit: April 21, 2012, 12:15:44 PM by F6BANGER » Logged
KSDragonRider
Salina, KS
« Reply #1 on: April 21, 2012, 11:57:37 AM »
looks like a trailer light controller to me.
Dalen & Shay -> Salina, KS
VRCC Member #33950
F6BANGER
Albuquerque NM
« Reply #2 on: April 21, 2012, 12:17:11 PM »
Sorry, I shoulda put what it does.  Its hooked up to the blinkers to make the Trunk lights work as blinkers also. I just dont know what it is called or who makes it.
chrise2469
Winnipeg Manitoba Canada
« Reply #3 on: April 21, 2012, 12:36:17 PM »
I'm just guessing without knowing which end goes to the trunk lights. if the lights go from the black trailer style plug to the interstate lights  it is a 5-4 convertor.
The other way around and it would be a vehicle to vehicle tail light convertor.  It takes your converted 4 wire signal-the trailer plug- and converts it back to a 5 wire signal.   Here's a different one:
http://www.etrailer.com/p-118158.html
You have to follow the wires to know what style of convertor you will need to replace the defective one.
Not much help but it's all I got.
EDIT:  The more I look at the picture it looks like a 5 to 4 convertor.  The 4 wire connector with the extended hood is a bit unusual and is confusing me a bit.
It could be early  hopkins 48915
http://www.etrailer.com/Wiring/Hopkins/HM48915.html
or a calterm 5-4
http://www.ebay.com/itm/Trailer-Light-Isolated-Power-Supply-Converter-5-4-wire-PM32-/290660635436
« Last Edit: April 21, 2012, 12:54:50 PM by chrise2469 » Logged
F6BANGER
Albuquerque NM
« Reply #4 on: April 21, 2012, 01:07:39 PM »
or a calterm 5-4
I think you are right chise2469
Thank you very much.
