July 09, 2025, 12:14:58 PM *
Author Topic: Sync/Valve Adjust/Pilot adjust  (Read 1772 times)
Bladedog
Lompoc, CA (Central Coast)
« on: May 22, 2009, 01:13:29 PM »
After my brake parts arrive and I'm back on the road, I believe the carb sync and valve adjust are next.  I believe I can build a sync tool no problem.  What should be done first?  Sync, pilot, or valve adjust?  Bottom line I'm trying to get better fuel economy, AND it seems to be running a little rough.
It's easier to get forgiveness than permission.
Dag
Country Rep. Norway
« Reply #1 on: May 22, 2009, 02:46:51 PM »
Carb sync. should be checked after adjusting the valves.
« Reply #2 on: May 22, 2009, 03:03:55 PM »
Sync should be the last thing done..
Momz
ABATE, AMA, & MRF rep.
« Reply #3 on: May 22, 2009, 07:28:26 PM »
I'd check all the vacuum lines first.
Repair/replace as needed
Check all intake o-rings and tighten all the clamps from the airbox to the carbs.
Then adjust valves when cold, adjust pilots, and finally synccronize the carbs.
The order/sequence is important to proper tuning.
ALWAYS QUESTION AUTHORITY!
