GJS
Today is the tomorrow you worried about yesterday.
Vancouver Island, BC, Canada
« on: April 25, 2012, 05:29:58 PM » |
Hi all,
I am interested to learn why Honda wants Rotor Bolts each time they are removed.
Why is this. They look fine to me. Maybe metal fatigue?
Anyone ever found any missing?
Best regards,
Glenn
The tragedy of life is not that it ends so soon, but that we wait so long to begin it. - W. M. Lewis
« Reply #1 on: April 25, 2012, 05:37:03 PM » |
It might be that you can only trust the torque specs in the manual when you have a new bolt with factory applied thread lock coating on it.
I've taken mine off, and reused them with blue loctite on them, didn't use a torque wrench when I put them back on...
-Mike "not dead yet"
« Reply #2 on: April 25, 2012, 06:29:35 PM » |
I've reused mine several times with locktight. I've also broken several. They are easy to break, so use a torque wrench.
GreenLantern57
Hail to the king baby!
Rock Hill, SC
« Reply #3 on: April 25, 2012, 06:53:24 PM » |
When a manufacture recommends replacement of a torqued bolt, it is usually because they have designed/specked the bolt to have little stretch. Now that the bolt is stretched, they want it replaced and not used. Truthfully, they can be used over and over again, some will break, some will not, but a manufacture has to recommend replacement bolts for design/safety/liability purposes.
How many of you will use a cotter pin over and over again until it breaks, same principal. All manufactures recommend a new cotter pin, everytime. Heck, I remember using nails on my bicycles to replace some cotter pins. Glad my uncle taught me better before I started riding motorcycles.
« Reply #4 on: April 25, 2012, 08:13:01 PM » |
I have found nothing other than internal engine parts that really needs a tork wrench. IMHO of course. 98K and nothings fallen off yet.  Hoser
« Reply #5 on: April 26, 2012, 03:06:58 PM » |
Posted by: Hoser
Usually, I use the "If this falls off, will I die" rule to torqueing a bolt or nut. And I try to use them when doing the exhaust manifold nuts, on the ones I can get too. I learned about 3 decades working in a Honda shop, if you over torque those puppies, you gonna pay.
« Reply #6 on: April 26, 2012, 06:05:12 PM » |
I'm more likely to under tighten than to bust something by over torking.(sic) Hoser
GJS
« Reply #7 on: April 27, 2012, 09:46:26 AM » |
Thanks Guys,
I think I'll just use lock-tite and a torque wrench. I learned long ago to trust engineers when they have gone to the trouble to give me a torque setting to start with. I'll stop shy of replacing what look to be Good bolts.
Cheers,
Glenn
RP#62
« Reply #8 on: April 27, 2012, 06:51:41 PM » |
SPOFF
« Reply #9 on: April 30, 2012, 07:16:38 PM » |
What's wrong with a nail?
da prez
« Reply #10 on: May 01, 2012, 09:17:53 AM » |
One trick to torquing properly is to make sure the threads are clean. In most cases, I use a thread tap and die to chase the threads and brake clean to clean followed by compressed air if possible. Run the bolt in by hand , then if free or a very slight drag is felt, put on the right type of locktite . Different types by color are for different applications. Just my two cents worth (B-4 taxes) da prez
