February 04, 2026, 08:52:17 PM *
Author Topic: Tire change update  (Read 1210 times)
Crashgordon74
Washington
« on: April 27, 2012, 11:42:09 AM »
Got both tires mounted using new 17" tire irons. Not near as hard as dismounting. I also installed billet valve stems. I purchased Dyna Beads to balance things out and then remembered I had spilled tire mounting lube inside the front tire. According to the instructions tire lube is tacky when it dries and can cause the beads to stick to the lube. So, I bought 3 bottles of Ride On to use. Question I have is how long can the tires sit after Ride On is installed. I am thinking of putting it in before I put the tires back on the bike and I may not be ready to ride for a few days. Also, what pressures should I run with the Bridgestones??
        Crash  Cool
JC
The Beast
Franklin, TN
« Reply #1 on: April 27, 2012, 11:52:34 AM »
I waited until I was ready to ride it before installing Ride-on, but I doubt that it would make much difference.
