November 24, 2025, 06:59:50 AM *
Author Topic: 5 Gallons from my pingle  (Read 1529 times)
SpidyJ
Murrells Inlet
« on: April 28, 2012, 07:50:35 PM »
Second time in 2 weeks........not good. What did I do wrong?......no reserve at all.  Do I hafta go back to stock to get my reserve back?
1999 Fast Black Interstate
Peace,
johnnywebb
« Reply #1 on: April 28, 2012, 08:28:55 PM »
Hey Spidey you did nothing really wrong, the Pingles don't really have a reserve its the cover on the fuel screen that determines the reserve. You can research it in the archives and it will tell you exactly what to do to fix this its really simple. Found and included the link below click and learn  cooldude
http://www.valkyrieforum.com/forum/tech_archive.cgi?read=1395108
« Last Edit: April 28, 2012, 08:37:37 PM by Robert » Logged
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: April 28, 2012, 08:37:45 PM »
When I installed a Pingel in my Tourer ChrisJ357 advised me the reserve would be about half due to the shortness of the pickup tube.  I could have removed the screen and extended the pickup tube but decided I'd rather have the screen.
Marty
junior
new hampshire
« Reply #3 on: April 29, 2012, 03:34:07 AM »
are you using it right? off is to the front of the tank res is pointing straight out to the left, and on is all the way to the back
« Reply #4 on: April 29, 2012, 06:49:40 AM »
« Reply #5 on: April 29, 2012, 08:24:53 AM »
Yep!  And now it's been well over five years and still no problems with it. The shorter pickup tube is why your reserve is so much less, the additional length corrects that but neither screen will fit...Pingle or OEM. Hence the need for an external filter.
« Reply #6 on: April 29, 2012, 09:55:57 AM »
If you are going to sweat on a longer tube, be aware that heat will destroy the 'O'-rings inside the petcock.
This has already been reported in the forum.
So employing a proper procedure is imperative.
Jus sayin'
SpidyJ
Murrells Inlet
« Reply #7 on: April 29, 2012, 10:49:48 AM »
I will rebuild the OEM when I get a chance.  Thanks for the advice.
Peace,
johnnywebb
« Reply #8 on: April 29, 2012, 12:07:48 PM »
Jus sayin'
You're correct, but I don't recall seeing anything posted with that problem. I sweated mine on using a soldering gun, not a flame. Only needed to get warm enough to melt the solder medium and the pickup tube below it near the body was quite cool. Just like me.  Cheesy
If you click on the link you'll see the extension tube doesn't go all the way to the bottom of the pickup tube. You just rough up the top 1/4" of the pickup tube and slide the extension over it. By using a soldering gun instead of a flame, the heat is localized instead of the entire tube being heated. Plus, I wrapped the bottom portion of the tube with some tinfoil held in place with  forceps. It got a little warm but the tube was nearly room temp. I think using a gun instead of a flame was the difference.
« Last Edit: April 30, 2012, 07:11:31 AM by John Schmidt » Logged
rws
1997 Valkyrie Tourer
North Dakota
« Reply #9 on: April 29, 2012, 03:53:41 PM »
petcock is labeled and here is a picture of the positions from the packaging...
Original VRCC Member Number 697
1997 Honda Valkyrie Tourer - 2019 Honda CRF450L - 2021 Honda Rebel 1100 DCT
« Reply #10 on: April 30, 2012, 03:56:15 AM »
If soldering the thing on is the problem then I know a epoxy called Marine tex that will do the job. If you put the tube on just mix a little epoxy and put it around the base of the extension tube and that should hold it fine. I have used this epoxy in gas before and it has held fine. Most any marine store and some hardware stores will carry it.
rws
North Dakota
« Reply #11 on: April 30, 2012, 03:16:49 PM »
follow up on Pingle fuel valve...
I installed a model 1311-CH yesterday and had a chance to test it out today.  Using the lever positions in the picture in my previous post I ran the main tank out and switched to reserve and got 19.8 miles (@ 65 mph highway riding) before running out on reserve.
