June 21, 2025, 08:11:58 AM *
Inzane 25
Author Topic: Need help  (Read 2139 times)
Chili Pepper
Michigan
« on: May 23, 2009, 11:40:15 AM »
I have a GW rider at the Q from Canada. He's riding a 2000 (1520) Wing and his alternator just went out. None of the local dealers have one. Is there a generic equivalent we might be able to get for him?
Thunderbolt
Worthington Springs FL.
« Reply #1 on: May 23, 2009, 11:45:05 AM »
Don't know if it will fit his 2000.
'97 Goldwing Aspencade
Part # is 31100-MT2-015
"The terminal & plastic insulator are different where you connect the alternator battery wire. You have to take off the capacitor that is mounted on the Gold Wing alternator and rotate the front housing to match the holes from the Valkyrie model so that it will fit."
BTW it costs much less than the one on the Valk.
This is the alternator part no. to replace the one on the Valk
Jeff K
« Reply #2 on: May 23, 2009, 02:51:40 PM »
He is on a wing, not a Valk. You don't have many options. Maybe some has one to loan?
« Last Edit: May 23, 2009, 03:06:56 PM by Jeff K » Logged
art
Grants Pass,Or
Grants Pass,Or
« Reply #3 on: May 23, 2009, 05:57:36 PM »
have him check with gwrra they might be able to get him a loaner
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: May 23, 2009, 07:28:30 PM »
Might be able to have a local shop rebuild it. You could have it overnited from this guy: http://mysite.verizon.net/resp3jbj/
He has Valk ones in stock, not sure about for the Wing.
Ken Tarver
North Mississippi
« Reply #5 on: May 24, 2009, 12:12:51 PM »
Compu Fire   http://www.compufire.com/
DeathWishBikerDude
« Reply #6 on: May 24, 2009, 06:55:01 PM »
A local rebuilder should be able to get it done in less than one day.
I imagine you could pay a little more for faster service if you explain your on the road.
Most big truck repair shops could suggest a local rebuild shop.
Much cheaper than buying a replacement,probably under $100 with the express service.
Zorba
Ride the Dragon
« Reply #7 on: May 24, 2009, 08:36:17 PM »
He should go with a "Compufire alternater" , check with "goldwingfacts.com" folks, they have the answers!
