February 04, 2026, 10:40:20 PM *
Author Topic: Can't tute my lady's horn  (Read 1582 times)
vw70blue
Tampa, FL
« on: April 29, 2012, 04:17:58 PM »
 Tried to use the horn while riding my 99 Tourer, no tute. (stock horn) I checked the fuse and it's ok. I turned on the key and hit the button and it worked. Tried it again and it didn't. I tried a bunch of times while riding. Most times it didn't work when I pushed the button. A few times it did. I'm pretty sure it's the horn button assembly.  If it is the horn button can it be fixed without getting a whole new turn signal/ horn assembly? If it can, what can I do? If it's not the button assembly, what could it be? Any suggestions will be appreciated.
F6MoRider
Lakeland, FL
« Reply #1 on: April 29, 2012, 05:21:35 PM »
Strange you should say this.  I had the identical thing happen on my '00 std and when I finally had time to tear it apart, the thing worked.  Couldn't recreate the problem after that but I still check when running high speed through the country.  I chaired it up to dirty electrical contacts as I did check the fuses and connectors when it happened.  Go figure...
If you find something, please post the follow up.
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
« Reply #2 on: April 29, 2012, 05:28:09 PM »
take the switch housing apart and clean those contacts and the blinker ones as well....lub with dilactic grease and all should be right again if its the switch.
vw70blue
Tampa, FL
« Reply #3 on: April 30, 2012, 04:01:11 PM »
After cleaning the horn switch twice, the horn still didn't blow.  tickedoff Everything in the switch looked good. So I said, what the hey, let me try another horn. It worked. Grin
Chiefy
Sarasota, Florida
« Reply #4 on: May 01, 2012, 04:06:22 AM »
Glad it's fixed.  A cheap volt meter from Harbor freight/Home Depot would have told you immediately what the problem was though.
« Reply #5 on: May 01, 2012, 05:55:00 AM »
I have had Honda beepers "freeze" up and quit working.  Maybe it's time to step up to a Stebel air horn.? Let em know your there!  ??? Roll Eyes
My rides:
csj
Peterborough Ontario Canada
« Reply #6 on: May 01, 2012, 07:59:17 AM »
I tried tootin my ladies horn once, still got a welt where she
hit me. Just a little love tap.
Allan
My 97 std.
Kastrup, Denmark, Europe
« Reply #7 on: May 04, 2012, 02:57:36 PM »
Is it possible to change to Stebel air horn without any change on the wirering?
(i hope you know the meaning of this. English is not my first languish)
wild6
(Old enough to know better)
Vernon, NJ
« Reply #8 on: May 04, 2012, 03:31:40 PM »
The Stebel needs a relay because it uses more power.
I dislike changing or cutting the harness, so I just crimped a mating spade lug to the end of a wire, plugged it in to the horn wire, and ran it back along the harness and under the seat where I put the relay and ran wires to power, ground and the Stebel from there.
Allan
My 97 std.
« Reply #9 on: May 04, 2012, 03:44:31 PM »
Thanks Vernon
I share your feeling about cutting the harness, so I will follows your direction.
Incredible! Ask a question in Denmark, Europe, and receive an answer half an hour later from USA. Great to be a member here :-)
Allan
My 97 std.
« Reply #10 on: May 04, 2012, 03:48:51 PM »
Wups! Not Vernon, but Wild6 from Vernon, NJ  Embarrassed
sugerbear
wentzville mo
« Reply #11 on: May 04, 2012, 10:32:07 PM »
and your english is better than some of our "american"  cooldude cooldude Grin
Allan
My 97 std.
« Reply #12 on: May 05, 2012, 12:58:18 AM »
Thanks Sugerbear  cooldude
