November 24, 2025, 05:48:04 AM *
Author Topic: bad tire wobble  (Read 1436 times)
harryo
« on: April 30, 2012, 06:05:35 AM »
I have a bad wobble between75 and 80 but doesnt do it all the time. Have about 1200 miles on a general altma 205 60  98valkrie tour
any ideas thanks
« Reply #1 on: April 30, 2012, 06:27:44 AM »
Sequence and retorque of the rear end? Did you also have tha front wheel off? Sequence and torque? Shock bushings? Proper air pressure? How are your tires balanced? How many miles on your machine? Head bearings? RIDE SAFE.
« Reply #2 on: April 30, 2012, 07:29:28 AM »
The first thing I would look for is bad upper shock bushings.  Photo from Rattlebars web site:
If they look like this, replace them with Honda P/N 52489-HN0-671, which are for VTX shocks, but are better quality then Valk bushings and are the same size.  There are other alternatives, which I'm sure others will pipe up with.
« Reply #3 on: April 30, 2012, 07:39:15 AM »
Good advice above.
Something else that can cause that is an under-inflated rear tire.
« Reply #4 on: April 30, 2012, 07:47:24 AM »
any ideas thanks
It sounds like you have already determined it's the tire!
jmann
Mesa,Az.
« Reply #5 on: April 30, 2012, 08:36:47 AM »
any ideas thanks
RD, how is him stating what tire he runs an indication of him already deciding it's the tire? Could he be just providing info for help?
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #6 on: April 30, 2012, 03:14:59 PM »
I had a car tire bead not seat uniformly causing the same wobble.  Has your tire done this, (on an intermittent basis) since it's installation?
Save a horse, ride a Valkyrie
