November 24, 2025, 06:59:36 AM *
Author Topic: Old tech answer - smelling gas?  (Read 1119 times)
KW
West Michigan
« on: April 30, 2012, 12:02:28 PM »
Over the winter I read a posting about cleaning out and/or unplugging "something" underneath the carbs. . . .  when/if you smell gas as you ride. A number of people said they had the same issue. I always smell a little gas going down the road. It's almost as if the bike is running too rich, but it's not. This 'tip' seemed to make sense and I copied it to a folder, but now can't find it and as you can tell, I can't really rmember the details. Anyone?  Thanks~
signart
Crossville, Tennessee
« Reply #1 on: April 30, 2012, 12:57:51 PM »
Well, I'll tell ya what mine was. "O" ring in the fuel rail. You might take a look, mine did not leak unless engine was running.
sugerbear
wentzville mo
« Reply #2 on: April 30, 2012, 02:11:14 PM »
maybe talking about the air box drain. found under the bike, tube hanging down with a "plug" in the end.
 intake runners tight? all 18 of them?
gas cap seal ok?
« Reply #3 on: April 30, 2012, 02:14:40 PM »
What I remember reading on fuel smell, multiple times, was the gas cap gasket failing, and being shimmed up/replaced with some thin rubber (like from an inner-tube).
I don't know if this could be smelled while riding however.
