November 24, 2025, 06:59:54 AM *
Author Topic: jet adjuster  (Read 882 times)
N0tac0p
« on: May 01, 2012, 04:41:53 AM »
in some string / link i found someone that had made a jet adjuster that would fit he tight area and was square so to count turns.  anyone remember who that may have been?
also if i followed the manual of "X" turns out, will that be good enough or should i be using the carb balancer with it?
Just trying to get a feel for what im in for
texaninsouthfl
Serving those who served us...
East Lake County, Florida
« Reply #1 on: May 01, 2012, 04:52:52 AM »
http://redeye.ecrater.com/p/5604503/stubby-pilot-screw-tool-on-bike
This is the tool you are referring to. Works great.
Bigwolf
Cookeville, TN
« Reply #2 on: May 01, 2012, 08:15:10 AM »
I believe "X" turns out will do quite well.  I does for me.  However, if you want to be perfect, then the fine tuning of these jets is done with a tach that can read changes of 50 rpm or less.  Reading a little farther in the Honda manual will explain that procedure.  I do not have such a tachometer so I just set mine 2 & 1/4 out and it seems to be running fine.
Bigwolf
