February 04, 2026, 10:36:10 PM *
Author Topic: AUX jack for MP3 player  (Read 1959 times)
Banky
« on: May 07, 2012, 05:44:56 AM »
  Where do you find the plug for MP 3 players such as i-pod and similar pruducts on a 1999 Interstate can not find it.
Thanks Guys I found it forever greatful!!!!!
« Last Edit: May 07, 2012, 01:52:40 PM by Banky » Logged
« Reply #1 on: May 07, 2012, 06:12:47 AM »
under right side cover.  It may be buried, but that's where they hide it.
Joe Hummer
Arnold, MO
« Reply #2 on: May 07, 2012, 07:33:29 AM »
The other way to find it is to take your seat off and chase the wires coming from the radio.  As stated, it should be behind the right side cover.  It may have a cover over it so you can't tell what it is.
1999 Valkyrie Interstate
ptgb
Youngstown, OH
« Reply #3 on: May 07, 2012, 08:23:20 AM »
If it helps:
BarendR
« Reply #4 on: May 07, 2012, 10:01:35 AM »
Not meaning to totally hi-jack, but ... I still haven't found my aux power leads, I suspect they were used for the pod mounted driving lights, meaning if I want to add an external power point where do I tie in?  The battery?
Also have a female connecter with two green wires behind that panel which would appear to match a male plug with two green wires coming from the starter??????  They are not plugged in.  Any idea what that is all about?
« Reply #5 on: May 07, 2012, 10:26:48 AM »
Why would the pod lights be hooked to an audio input?
X Ring
VRCC #27389, VRCCDS #204
« Reply #6 on: May 07, 2012, 11:08:35 AM »
They're not Hoser.  Pod light draw power to activate the relay from the aux power circuit.
BarendR, what you're going to need to do is install an aux fuseblock.  Get a 40 amp relay and activate it with the aux circuit.  The relay provides power to the fuse block and then you send it out from there to your various accessories.  You'll need 2 circuits for the pod lights.  1 to activate the relay and the other to provide power to the lights.  While you're at it you're also going to have to common ground block for the ground wire of the pod light relay to attach to.
It's not hard.  A little time consuming and you have to decide where you want to put the aux fuse block.  Mine is mounted on a piece of lexan in the back compartment of the battery box.
Marty
hillbilly
Chapmanville WV
« Reply #7 on: May 07, 2012, 05:38:07 PM »
I found mine under seat in front of radio.
BarendR
« Reply #8 on: May 11, 2012, 02:14:28 PM »
X Ring, so you are saying to get a 40 amp relay to power an aux fuse panel and hook it to the aux wires which are protected by a 5 amp fuse (if memory serves).  so essentially your whole aux fuse panel is limited to 5 amp????
Would it not be simpler to wire an aux fuse panel straight to the battery???
X Ring
« Reply #9 on: May 11, 2012, 02:37:11 PM »
No, you use the aux circuit to activate the relay.  Next to the fuse panel is a black cover that has a weird looking metal fuse.  Remove the top screw and put the screw through the ring terminal on the wire supplying bike power through the relay to the aux fuse panel.
Marty
« Reply #10 on: May 11, 2012, 02:39:43 PM »
The five amp circuit only activates the aux panel, which is wired direct to the battery or to it;s buss bar,as described above. It is activated whenever the key is on.  Panel is only on when the key is on and the relay only activates the relay.  Power to the accesories goes only to the accessories, not to the five amp circuit.  Hope this helps, Hoser
« Last Edit: May 11, 2012, 02:41:24 PM by Hoser » Logged
X Ring
« Reply #11 on: May 11, 2012, 02:48:04 PM »
Did a search and there's a pic in vanagon40's post showing the fuse (fusible link0 I'm talking about.
http://www.valkyrieforum.com/bbs/index.php/topic,15292.0.html
Marty
