February 04, 2026, 09:15:58 PM *
Author Topic: 2003 Standard Evap Canister  (Read 1419 times)
jdaker
« on: May 07, 2012, 03:43:24 PM »
There appears to be a vent tube that runs from the rear of the fuel tank and terminates at the kick stand bracket on my 2003 Valk Standard (CD).  There is a tee fitting in this tube and there is no tube connected to the tee off of the fitting.  From what I've seen on parts diagrams there should be a tube from the tee to an evaporative canister.  I don't find any disconnected tubing anywhere nearby.  Unless it is well hidden, I don't see an evap canister either.  I have capped off the open tee for now.  Is there supposed to be a tube from the tee to an evap canister?  Where did they hide the canister? Thanks for any help!
Jim
Mentor, OH
ptgb
Youngstown, OH
« Reply #1 on: May 07, 2012, 05:01:08 PM »
I believe that only the California Valks have the canister. That would explain why you can't find it. I also believe that the tee should remain open as it was.
Hopefully someone will correct me if I'm wrong.
p.s. - we have a few riders in your area (Mentor/Perry/Akron/Youngstown/etc). Hit me up via PM if interested in hooking up for a ride... we get together pretty frequently. PM me.
« Reply #2 on: May 07, 2012, 05:08:36 PM »
Yes the "T" needs to remain open. It prevents siphoning of tank if it's overfilled. The Charcoal canisters are only on the CA emmissioned bikes.
Grandpot
Fort Mill, South Carolina
« Reply #3 on: May 07, 2012, 07:25:26 PM »
+1 for Sandy
jdaker
« Reply #4 on: May 08, 2012, 02:38:23 PM »
Thank you!
I noticed some posts about people looking for red lenses for their rear turn signals. I found mine on Ebay.
http://www.ebay.com/itm/Honda-VTX-and-Shadow-red-turn-signal-lens-/330694995003?pt=Motorcycles_Parts_Accessories&hash=item4cfef52c3b&vxp=mtr#ht_2218wt_1185
