April 30, 2026, 02:01:33 PM *
Author Topic: Shock Absorber - Upper Mounting Bolt Torque Value  (Read 1310 times)
Big Ed
2001 Standard - 1998 Project Bike
Dallas - Fort Worth, TX
« on: May 08, 2012, 05:37:23 PM »
Hello Brethren,
The Honda Service Manual has contradicting info for the:
Bottom of Page 312 (14-1) says "47 lb.ft", and
Top of Page 321 (14-10) says "20 lb.ft"
Which is correct?
I'm thinking it's "20 lb.ft", and the "47 lb.ft" on (14-1) is a typo.
Thoughts?
WDAN
Irving, TX
« Reply #1 on: May 08, 2012, 07:02:42 PM »
Ed,
I can't reply to the torque values of these bolts but can relate a very recent experience.
I added the upper shock chrome bolt covers and replaced the ugly OEM bolts with chrome.
I promptly lost one from vibration (These buggers are almost $5 each)
Went back to Elliot's and bought another chrome bolt and blue threadlock. No further loss of bolts.
 Oh, I just used "feel" not trusting my torque wrench or my experience using it.
WDAN
Irving, TX
Mr.BubblesVRCCDS0008
« Reply #2 on: May 08, 2012, 07:20:19 PM »
I'm thinking 20 ft lbs. That is a very small bolt to torque to 41 lbs. I 've always just snugged them up with a 14 mm wrench and called it good.
olddog1946
Moses Lake, Wa
« Reply #3 on: May 08, 2012, 10:06:41 PM »
If you use 41 lbs, you'll be looking for some new mounting posts.  There are indeed errors in the manual, so if in doubt check the charts in the chapters concerned then use that against the paragraph covering what you are doing. USE the SMALLEST value.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
WDAN
Irving, TX
« Reply #4 on: May 09, 2012, 07:16:20 AM »
Also, don't forget the Threadlock.   Wink
« Last Edit: May 09, 2012, 07:24:22 AM by WDAN » Logged
WDAN
Irving, TX
Big Ed
« Reply #5 on: May 09, 2012, 12:24:48 PM »
Roger that. Thanks.
Big Ed
« Reply #6 on: May 09, 2012, 12:25:16 PM »
Roger that. Thanks.
