April 30, 2026, 02:00:01 PM *
Author Topic: Took longer than I thought it would...Rear end /tire change  (Read 1485 times)
hotglue #43
« on: May 12, 2012, 08:06:20 PM »
This morning I got the rear wheel pulled and got the new tire on....Pulled the pumpkin to clean, and when I turned it on end to be sure the holes in the pinion cup were clear....WATER CAME OUT!!!!!  Whats up with that?????
  There was quite a bit of rust in the outside bottom of the pinion cup area.  The only area I can imaging the water coming from is the boot at the U joint....
  Pulled the swing arm and the U joint... could see a rust line running down inside the housing for the driveshaft....  Cleaned everything up... U joint looked ok.... put it all back together... and made sure the rubber boot was on good.  Saw no cracks or holes in the boot...
I will need to keep an eye on it!!!!
  Flushed the rearend several times.. til it drained clear.... put it all back together... Mobil 1 75/90...  put the wheel back on.... the realized I had bought more lights for the rear... and It would be easier to work it from the back if the wheel was not there.... pulled the wheel... hooked up the lights, re-installed wheel.. torqued axel. torqued pumpkin, put the shocks back on....  Time ta take a break....  It's 10 pm... and I just came in the house.
By the way... new O-rings all round...
« Last Edit: May 12, 2012, 08:07:57 PM by hotglue #43 » Logged
 blue=3 times
 green=at least 4 times
« Reply #1 on: May 13, 2012, 04:52:03 AM »
Yopu need to charge/pay yourself at least $500 Id guess a dealer would be well above that.......good work!  cooldude  Sounds like you averted a catastrophe.
« Reply #2 on: May 13, 2012, 01:42:12 PM »
Wonder when the last time you rode in the rain was?
Man, glad you caught it!!!
Hay Cool
blotar
VRCC #32549 VRCCDS#0237
Crosby, Texas
« Reply #3 on: May 13, 2012, 05:12:22 PM »
Great catch Mark,
 what did you lube your splines with?
blotar
http://vrcc.photostash.com/vrcc_32549/VisitedStatesMap3.jpg
1998 Valkyrie CT
1995 V-Max [img width=347 height=175]
1995 Yamaha Virago 1100
1994 Suzuki GSX 1100 G
1995 Honda Shadow 1100
1994 Honda Magna 750
196? BSA Hardtail
1973 K3 Honda 750
1964 Allstate 250
hotglue #43
« Reply #4 on: May 13, 2012, 07:48:00 PM »
I used a Bel-Ray moly lube on the splines... and a Bel-Ray waterproof grease on the shaft splines.
All the splines and driveshaft/u-joint  connections looked good.  Will continue to look for water in the rearend.....  none of the o-rings looked bad...  At least I know now that the boot at the u-joint  on properly...  Like I said... I will keep an eye on it.....
Now I just have ta figger out which is my good eye.... coolsmiley
 blue=3 times
SideCar
Bikers don't need shrinks!
Colleyville, TX
« Reply #5 on: May 14, 2012, 06:44:39 AM »
Dang low water crossings!
Glad you caught it early enough.
RainMaker
Arlington, TX
« Reply #6 on: May 14, 2012, 07:43:14 AM »
It really sounds strange having water there.  When you changed the engine oil, did you have any water in there?  Just wondering if this bike might have spent some time a bit "submerged".
Very happy you caught the problem before it became a really big one.
RainMaker
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
hotglue #43
« Reply #7 on: May 14, 2012, 02:58:53 PM »
Never been under water as long as I have had the bike....Where is Subman when ya need him..LOL
  I went thru the rearend when I got the bike... and every 10k miles since..  this was the 3rd time.... no water before.
It looked like the front end of the boot had come out of the groove....I have ridden in some pretty good rains... but no standing water.  there was maybe a 1/4 oz of water... but that's tooo much...
 blue=3 times
