August 19, 2025, 05:55:25 PM
How do I set a volt meter
Topic: How do I set a volt meter (Read 1104 times)
May 14, 2012, 09:32:37 AM »
So I can identify a hot wire on a motorcyle?
Re: How do I set a volt meter
May 14, 2012, 10:48:33 AM »
1. Set your volt meter to DC voltage at whatever range is greater than 12V (e.g. 0-20V, 0-50V, or 0-100V).
2. Firmly connect your negative lead (usually black) to either the negative terminal on your battery, or a good frame ground.
3. Start touching wires or terminals with the positive lead (usually red) until you find what you're after (meter reads 12V with the engine off or 13-14V with the engine running.
What are you adding to your bike? One or two of us might have ideas about the best place to take power from.
jer0177
VRCC 32975
Pittsburgh, PA
May 14, 2012, 10:49:20 AM »
You want to use a setting that will provide >= 12VDC.
Easier yet - pick up a test light - it's got a probe on one end and a clamp on the other, lights up when you hit a hot wire.
May 14, 2012, 11:59:40 AM »
Quote from: jer0177 on May 14, 2012, 10:49:20 AM
I have one of those tucked away somewhere. Thanks.
May 14, 2012, 12:00:01 PM »
Quote from: Gryphon Rider on May 14, 2012, 10:48:33 AM
Thunderbolt
Worthington Springs FL.
May 14, 2012, 02:42:45 PM »
What Gryphon said. Good description. Make sure the black wire is in common and the red one in volt/ohm, not amps. Some types of meters have several places to plug in the wires.
Reply #6 on:
May 14, 2012, 02:45:27 PM »
Quote from: Thunderbolt on May 14, 2012, 02:42:45 PM
That's like the one I have.
Electrcity is the work of the devil
RP#62
Gilbert, AZ
Reply #7 on:
May 14, 2012, 05:49:31 PM »
Make sure your meter is set on DC Volts. If you set it on DC Amps, you'll need extra fuses for your meter.
-RP
=> InZane XXV
