January 28, 2026, 06:26:55 PM *
Author Topic: 440 shock adjustment  (Read 2581 times)
Ken 11861
Lunenburg, MA
« on: May 26, 2009, 05:55:54 AM »
I have the 440 13" standard shocks. Progressive Suspension says the shocks are set at the lowest setting when shipped. So far I've turned them a total of 4 turns down clockwise and I think I'm real close to where I'll leave them set.
Does anyone know how many turns they actually can go before the adjustment bottoms out ?
Thanks, Ken
2001 Valk (72,500 5/2011) & 2009 ST1300 (new 5/10)
Warlock
Magnolia, Ms
« Reply #1 on: May 26, 2009, 06:45:30 AM »
I'm thinking 8 to 10 total rounds.
David
MP
North Dakota
« Reply #2 on: May 26, 2009, 06:58:08 AM »
If I remember right, it is 10 turns.
MP
"Ridin' with Cycho"
« Reply #3 on: May 26, 2009, 07:13:24 AM »
MP
Ten whole turns? I can see three (or four) threads above my spring cover now,
I can turn it all the way until I can see 10 threads????
I thought I was about maxed out, and am planning to send the shocks back to
get heavy duty springs soon. It would be cool if I didn't have too...
I guess I could just turn the spring cover until it quits going and nothing bad would
happen and all doubt would be gone...?
Ken 11861
Lunenburg, MA
« Reply #4 on: May 26, 2009, 10:15:53 AM »
Great info Guys !!! Thanks
Sounds like I got plenty of turns to go. Progressive recommended the 440 Std for me at 165 lbs, they are definitely stiff enough for me and handle a lot better than my 62k mile OEM's. I've been cranking down the adjustment just a couple turns at a time for when I ride with the wife. Makes it firmer for me when solo but life is a compromise (I hear). Besides when she's happy, she allows me to be happy too.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #5 on: May 26, 2009, 12:40:08 PM »
Sorry, gotta disagree herre. The 440s are marked with lines. After turning the tops down for many turns, you will see an indented line on the shock body. I have never had to turn my HD 440s down past the third line, so I am not sure how many lines there are. I never bother counting turns, just set both on the same line. Lips Sealed
Steve K (IA)
Cedar Rapids, Iowa
« Reply #6 on: May 26, 2009, 03:03:44 PM »
Ok, here's what I have done.  Crank them down until they stop...both shocks.  Now take a black Sharpie and color in the divot on the top collar that is in the outward most position.  Now you have a reference point to work from and will always know the shocks are set the same.  Makes it easy to count the turns. cooldude
States I Have Ridden In
« Reply #7 on: May 26, 2009, 08:50:31 PM »
440's go 10 turns, and it takes 8 turns on the standard rate shocks (4213) to approximate the lowest setting on the heavy duty shocks (4221).
