April 01, 2026, 02:07:28 AM *
Author Topic: riding season done  (Read 3024 times)
robin
Get on it and RIDE!!
Hardwick NJ
« on: May 17, 2012, 05:01:41 PM »
Well talked to the doc today and i go under the knife the 30th of this month for neck surgery going to fuse 5,6,and 7 hoping to make Inzane by car. tickedoff tickedoff
Popeye
Plainfield, IL
« Reply #1 on: May 17, 2012, 05:05:05 PM »
Good luck with the surgery.  Had lower back done years ago.
Popeye
mhallock
Sussex County, NJ
« Reply #2 on: May 17, 2012, 05:21:57 PM »
Robin,
Didn't know you were having a problem with your back........too much pain to get a ride in before surgery?? Maybe we could take a ride up to visit Bonzo and the NY crew?? How long a recovery period are they advising?? What the heck!!!
Mark
eric in md
« Reply #3 on: May 17, 2012, 05:30:17 PM »
man hate to hear this .. best of luck just keep it shined up .. send judy to hillbilly wait maybe i can pick her up .. really robin just take it easy many more yrs to ride .
Phil57
Jenison MI
« Reply #4 on: May 17, 2012, 05:38:43 PM »
Good luck with the surgery and the recovery. Hope all goes well.
« Reply #5 on: May 17, 2012, 06:02:28 PM »
I wish you the best Robin my son has destoryed his back when he was 17 he will never be the same .
Valkahuna
DeLand, Florida
« Reply #6 on: May 17, 2012, 07:02:14 PM »
I ended up one evening totally incapacitated by pain. Worst thing that ever happened to me. Tests showed three herniated and three other disks bulging in my neck. On top of everything, they discovered that I have congenital stenosis (narrowing of the canal in the spine that the spinal chord is supposed to fit in) which causes the nerves to all be vulnerable to pinching.  Sad
Anyways, normally they go in through the front of the throat to work on those disks, but doing so means they have to fuse the one they are fixing. With my neck as bad as it was, the Docs (more than one) decided that if they fused one, they would have to do them all, since the fused one would put more strain on the others and they were not in good enough shape to take the stress. NOT GOOD!!! I'd be walking around like I had a 2 by 4 screwed to my head and butt. Neither the Docs or I wanted that. Shocked Since I had no problems prior to that day, it was decided to try to find the ONE THING that went wrong that  day. Talk about tests!
Tried all kinds of therapies while they were trying to find the problem, with no results. So... they put me on oxycontin, and Anti-vert (to lessen the dizzyness and pain I was having). This went on for three months. No driving, no nothing! Did I mention my youngest son got married in the middle of all this? Finally did a discectomy (spelling?) in February, with admonishments to "be careful", etc, etc.
Bottom line is this. That was in 2004, I have to be careful, my right hand and fingers are still numb (permanent nerve damage) but I am doing what I want, including riding. It was tough getting off the oxy (don't want to go there again).  Angry
So what's the point of of this long story? To let you know that no matter what they tell you, be sure that it is necessary to do the fusions. Tough to turn your head to look behind you riding your bike when only half of the vertebrae can move independently, but more importantly there is a light at the end of the tunnel, and it's not the train! This too shall pass! cooldude
2014 Indian Chieftain
2001 Valkyrie I/S
Karen
Boston MA
« Reply #7 on: May 17, 2012, 07:05:09 PM »
Keep the faith, Robin, trusting that it will all work out well.
T-Bird
Cleveland, Tennessee
« Reply #8 on: May 17, 2012, 07:10:31 PM »
Good Luck Robin. I didn't know you were having problems. I hope the surgery goes well and you will be riding soon. I have my fingers crossed now about the Hillbilly ride, but will have to make a discision soon.
I'm very worried I screwed my lower back up with the fall I took 3 weeks ago. The broken ribs are still hurting but not as bad as before. The 2 vertabra I chipped must be where most of my severe pain is coming from. I go back to the Dr. in 3 more weeks for a CT scan & x-rays to see how everything looks.
Flask
Inglis Florida
« Reply #9 on: May 17, 2012, 07:13:40 PM »
Best of luck to you my friend !!!!!!!
You and Judy will surely be missed at the Hillbilly Hwy Run.
Please keep us all advised  cooldude cooldude cooldude cooldude
Momz
ABATE, AMA, & MRF rep.
« Reply #10 on: May 17, 2012, 07:14:27 PM »
Good luck.
Been there, and got a scar to prove it. Six weeks later Iwas riding the "Valhalla Voyage".
Two years ago I had even more intense spinal chord surgery. My doctor told me I'd never drive a car again.
Well I told him I'm a motorcyclist and it wasn't going to stop me.
Trust in yourself and you'll be riding very soon.
ALWAYS QUESTION AUTHORITY!
FryeVRCCDS0067
Brazil, IN
« Reply #11 on: May 17, 2012, 07:27:09 PM »
I blew a disk in my neck and pinched the nerve to my left arm and hand in 1996. It was the most incredible pain and it never let up. Like a tight, hot wire running down my arm, and every once in a while, it was as if someone sent a large voltage down the wire. My coworkers got a bang out of my symptoms to be sure since I would jump when the voltage thing happened. It hurt so much I would sweat constantly and my last thought  before falling asleep was the dread of waking up to the same pain.
I went to several Doctors, each of which had a different diagnosis. Finally, a sports medicine Doctor diagnosised it as a blown disk in my neck pinching the nerve. He said that fusing the disks would probably be the only cure for me.
I didn’t trust anyone to operate on my spine and toughed it out for a couple more years which did cause some permanent nerve damage to my left arm. I tried several chiropractors during that time, none of which helped. The third guy I went to said he could fix the pain, and he did. It’s still gone, even after all these years. If I have to work on something overhead I sometimes pinch the nerve again and I go back to him for an adjustment and he fixes it again.
I can’t promise it would work for anyone else, but I can say with absolute certainty, Dr Frankville saved me from spinal surgery and greatly increased my quality of life.
Good luck to you whatever you decide.
robin
Hardwick NJ
« Reply #12 on: May 18, 2012, 02:31:10 AM »
Thanks everyone looks like i have all the symptoms ya'll have had the pain is sometimes unbearable on my left side but life goes on.
BigMac NJ
Nike Hercules site Malibu inset FT. Bliss,Tx
Keyport New Jersey
« Reply #13 on: May 18, 2012, 03:51:17 AM »
Robin,
Good luck with the surgery !
Kevin
New Haven, Indiana
« Reply #14 on: May 18, 2012, 04:29:58 AM »
Robin, my son Mark, Mad6Gun, badly damaged a disc in his neck, work connected,  lots of pain.  Neck vertebrae are nothing to fool with.  The surgeons went in and fixed it by fusion and a piece of bone from a cadaver.  He's ok today.
I had back surgery on L4-5 about 14 years ago.  The pain was so bad that they had to give me a shot while I was waiting on the gurney for surgery. Ii was stenosis, an arthritic spur pressing on the nerves.  I woke up pain free and was discharged the next morning.  I was walking that afternoon with no pain.
Hope you get back to riding soon.
Chiefy
Sarasota, Florida
« Reply #15 on: May 18, 2012, 04:42:24 AM »
Best wishes for an uneventful procedure and a quick recovery.
Devl
Saginaw Michigan
« Reply #16 on: May 18, 2012, 04:52:15 AM »
Oh Mannnnnn....sooo sorry to hear this Robin!
Surgery should always be a last resort but it sounds like your in such pain that your there.
Good surgeons can do some miraculous things.  I know some folks that have parts of cows tails in their neck and didn't slow down abit.
Prayers to you for a successful surgery and a complete recovery, hang in there cooldude
Please keep us all informed during the process.
Devl
Cattman
Franklin, IN
« Reply #17 on: May 18, 2012, 05:07:02 AM »
I had C6/7 worked on 5 years ago for the stenosis coming out the left side. Same symptoms with the electrical charge and knotted up muscle in the shoulder for over a year. Surgury relieved the pain immediately. No fusion, only removal of some bone to free up the nerve.  cooldude
Ice
On a road less traveled.
« Reply #18 on: May 18, 2012, 05:27:34 AM »
Man Robin, we were looking forward to seeing you two at the Hillbilly, but I truly understand, I have crusched C3-7 and my Dr. wanted to do surgery a few years ago and I told him no, only if the pain gets worse, which so far I have a handle on.
Best of luck my friend, hope you back on the Valk soon.
Yuri
« Reply #19 on: May 18, 2012, 10:17:46 AM »
Robin that is a tough one.
We are hoping that the surgery works and you are back to your ornery self in no time, and able to ride and turn your head so you can enjoy the wind in your face and have your lovely wife speaking into your ear in thru the intercom in that sweet voice of hers  sayin   " WILL YOU PLEASE GO FASTER"
Look forward to seeing you this summer somewhere
Paxton
So Cal
« Reply #20 on: May 18, 2012, 01:45:33 PM »
Robin;
Good wishes for your recovery. Smiley
These days I hear that those kinds of surgeries have become more commonplace, especially when they use titanium. ???
I'm just talking 'bout what I hear. Certainly not backed up by any expertize on the subject. Roll Eyes
Notwithstanding, I hope that advances in science and procedures benefit you. Lips Sealed
Get well soon. coolsmiley
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
GiG
NEAR the "In 'n' Out Burger"
« Reply #21 on: May 18, 2012, 02:02:34 PM »
Robin, buddy, sorry to hear. I face a lot of the same issues, and have been putting it off for a long time. Seems to be getting worse, lately.
Was looking forward to seeeing you and Judy.
Heal up fast!
GiG
Everything is - Nothing is .
(send it to OSS)
This isn’t Rocket Surgery
Bonzo
« Reply #22 on: May 18, 2012, 04:07:30 PM »
So sorry brother, i guess we do the wino tour by car!
Woops, I'm sorry.
xman
Lincoln Park NJ, Valk Home Lackawaxen PA
« Reply #23 on: May 19, 2012, 06:07:26 AM »
Sorry to hear you have been living with this pain. What Valkahuna said is the reality. As I had told you my wife has always had leg pain at night. This last year the pain has escalated to just about muscle. Countless doctors, every diagnosis, spinal injections, nothing helped. Until the physical therpist said I have never seen some one with such knotted muscles. She said see a doc that did not work at the spinal center she worked at, " he has helped a lot of people" In 5 miniutes doc said you have fibermayalgia, arthritis, and sciata. What a difference since then, not a cure, but just knowing what it is not, made the difference. So my point , my wife was about to do anything they said, and each doc thought they knew what the issue was, but. She just needed to find the right guy. Robin, my only suggestion,  be sure you have done your homework, exhausted all the diagnosis and options.
Good Luck
Tom
Strider
Broussard, Louisiana
« Reply #24 on: May 19, 2012, 06:08:28 AM »
Speedy recovery brother!!!!
hotglue #43
« Reply #25 on: May 19, 2012, 06:26:43 AM »
Robin
  Sorry to hear this.  Back pain can really be a killer!!!!!  Hope your painfree and healing up ta ride soon!!!!
 blue=3 times
 green=at least 4 times
NJF6Cowboy
« Reply #26 on: May 19, 2012, 02:46:15 PM »
Robin & Judy,
Just got home from Rhode Island to read this sad news. Best of luck with the surgery.
If you need any help I am just up the road and would be glad to help.
Stan
G-Man
White Plains, NY
« Reply #27 on: May 21, 2012, 01:46:51 PM »
Hope all goes well, Brother.  Good thoughts from me and Cheryl!
