February 05, 2026, 12:52:50 AM *
Author Topic: What size new shocks?  (Read 1547 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: May 19, 2012, 07:47:04 PM »
I have a 99 Standard set up for solo.  I am 6'1" about 225lbs, 34 inch inseam.  I still have the original shocks on my Valk and would like to replace them with Progessives.
I would like to raise it (the seat) about 1 inch higher. (Originals already set on highest setting)
What shock does anyone recommend and what length?
Thanks,  Mark
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
« Reply #1 on: May 19, 2012, 08:44:59 PM »
If your ride is fine, then why not just add an air bladder (forget what they call those cushions) and "sit on it".
« Last Edit: May 19, 2012, 08:48:44 PM by gordonv » Logged
JaysGone
Delray Beach Florida
« Reply #2 on: May 19, 2012, 09:17:33 PM »
Mark
I dont think you can go higher.
13 inches for shocks is max I believe.
Im new to the bike and could be mistaken.
I just took off a set of Progressive 440s.
Very stiff ride even on the softest settings for me.
I put on a set of OEM Monday on the middle 3rd setting.
Rides not a heck of alot different to me.
Still stiff but a bit more rebound.
Same weight as you, solo setup too.
I have to get a spanner wrench so I can try the OEMs on 1 and 2.
If I put on my double seat that raises me up a bit more.
The stock solo seat I have is good for me but Im 5'10 with a 30 inseam.
      1999 Valk - SOLD
      2005 Yamaha RoadStar
« Reply #3 on: May 19, 2012, 10:31:02 PM »
With your height/weight I'd get Progressive 13" 440 HD's. The spring rate will raise the rear a bit but you'll appreciate the ride and improved handling in the corners.
« Reply #4 on: May 20, 2012, 04:36:59 AM »
+1  cooldude
I don't have experience with them, but people also really like Works Performance shocks,
and there's a VRCC supporting vendor who sells those... http://www.xf6-custom.com/
Brian
Monroe, NC
« Reply #5 on: May 20, 2012, 05:58:31 AM »
Air Hawk is the air bladder cushion, I use one on the driver seat and the passenger pad. cooldude
Dano
Gwinn, MI
« Reply #6 on: May 21, 2012, 05:26:04 AM »
Same set up here, Progressive 440's 13".  At 6'2" and 205, it will raise the rear end of the bike about an inch which gives you a little more clearance in the twisties.  Since I ride sole and have the back seat removed, I had to send the Progessive shocks back a few times to get things right.  The HD shock was too stiff for solo, so I had them heat treat the spring.  All is well for over 15 years.
Dan
JaysGone
« Reply #7 on: May 21, 2012, 02:48:21 PM »
Dan
My 440s are also going back.
I hope they will put in the regular spring.
With the HD spring commutings a bit on the harsh side.
Mark
The 440s are a bit on the high end of things but they may be for you.
Id look into the 412s too.
Similar and a heck of alot less expensive.
Ive been reading the Progressive site and there is alot of options there.
« Last Edit: May 21, 2012, 02:56:27 PM by JaysGone » Logged
      1999 Valk - SOLD
