November 24, 2025, 01:55:31 PM
Carb tubing 1999 IS
Topic: Carb tubing 1999 IS (Read 866 times)
IBE
Carb tubing 1999 IS
May 20, 2012, 09:09:39 AM »
I have a tube coming from a "T" that is between carbs 4&6 that goes to other "T" with a hose that goes to "T" Between carbs 3&5, What connects to the open end of the "T" where the 2 tubes meet? These tubes r for air not Fuel they set at the top of the carb rack.
IBE
BonS
Blue Springs, MO
Re: Carb tubing 1999 IS
May 20, 2012, 01:34:40 PM »
The two tubes insert into two holes that are in the rear carburetor brace that runs between carbs #5 & 6. The two tubes are vents and just point downwards after being inserted in their respective holes.
=> InZane XXV
