March 30, 2026, 09:27:22 AM *
Pages: 1 [2]   Go Down
Author Topic: I checked and adjusted my valve clearance last weekend.  (Read 11503 times)
Pappy!
Central Florida - Eustis
« Reply #40 on: January 18, 2017, 05:22:12 PM »
There are a couple of items that I take exception to in this thread.
The first is the concept that the Valkyrie had solid valve lifters.
This is not correct.   The Valkyrie has no valve lifters at all.  Simply a cam, rocker arms and valves.
The second is that valves tend to tighten up rather than loosening up.
This again is incorrect. As the rotating parts wear, clearances increase. The valves do not rotate.
If your Valkyrie is running fine, there is no need to suspect a valve adjustment is needed.
I take exception to your exception.  If the valve face/seat wears faster than the stem, then you loose clearance over time as the valve seats deeper in the head.  I've seen it go either way and sometimes vary from engine to engine of the same type, but more often than not you loose clearance over time.
-RP
Absolutamentally  correct!  Very normal for valves to lose clearance as the valve/seat wears. And, since the faces are at an angle it does not take much wear at all to see a difference.
« Last Edit: January 18, 2017, 05:24:44 PM by Pappy! » Logged
Paladin528
« Reply #41 on: January 19, 2017, 06:11:18 AM »
Either way the clearance is measured cold because when the engine is hot the clearance is significantly less.  The purpose is to ensure MINIMUM clearance when the engine is at operating temperature. Setting the valved over tolerance would leave a more significant gap when hot which increases wear on the stem and rocker.  Too tight a setting can cause the valve to not completely seat.
As I have said before, the Honda engineers are not chumps.  they are some pretty bright guys.
at 50K I had one (1) Valve that was .001 out of tolerance
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« Reply #42 on: January 24, 2017, 07:48:51 PM »
Just checked mine today...Have a 99 CT...Had to adj. #3 In/Exh, #4 In, #5 In...Was surprised because she only has 26580 miles on her...Got her when she was 24500...Seems to be ok...I sill get some popping every once in awhile...checking for vac. leaks and will rebuild carbs/ syn. next...!!!
mrgeoff/SANDMAN
Pages: 1 [2]   Go Up
