March 31, 2026, 11:59:58 PM *
Author Topic: Tools Explained.  (Read 1007 times)
Dave Ritsema
South Bend IN
« on: May 29, 2012, 02:28:16 PM »
As many of us perform our own repairs, I felt that the information below may prove valuable.  2funny
Tools Explained
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh--!'
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON-OF-A-B!TCH TOOL: (A personal favorite!) Any handy tool that you grab and throw across the garage while yelling 'Son of a B!TCH! ' at the top of your lungs. It is also, most often, the next tool that you will need.
VRCC 2879
Lake City Honda Warsaw IN
Stanley Steamer
Athens, GA
« Reply #1 on: May 29, 2012, 02:32:35 PM »
As an amateur woodworker, I can attest to almost everyone of these!!!........ cooldude Cheesy
Stanley "Steamer"
"Ride Hard or Stay Home"
« Reply #2 on: May 29, 2012, 08:23:41 PM »
I think my favorite on this is the wire wheel one, I cant tell you how many times that has happened to me.
Spirited-6
Nicholasville, Ky.
« Reply #3 on: May 30, 2012, 05:43:31 AM »
You will never how much I enjoyed this. I have been "PLAYING" with tools for 60 + years and NEVER had any of this happen to me.  crazy2
Spirited-6
bassman
« Reply #4 on: May 30, 2012, 05:52:57 AM »
I have some of those tools and they work EXACTLY as described !   2funny
hotglue #43
« Reply #5 on: May 30, 2012, 06:28:01 AM »
Roger that!!!
 blue=3 times
 green=at least 4 times
Reb
Greeneville, TN
« Reply #6 on: May 30, 2012, 06:44:23 AM »
I tend to use the rooster-S*ck*r, Piece of Sh!t, Mother-F*ck*r tools at time. My Navy vocabulary tends to work at its finest sometimes in the garage.  cooldude
2022 Honda Goldwing Tour DCT
1999 Honda Valkyrie IS
1972 Honda CB350F
1978 Honda CB550K
1968 Honda CL175 Sloper
czuch
vail az
« Reply #7 on: May 30, 2012, 07:29:33 AM »
To my loving wife as she helps me in the garage,
"No honey, the other dammned thing that looks just like that".
« Reply #8 on: May 30, 2012, 08:46:49 AM »
I have tried-more than once-to explain to 2 wives that when i politely(usually no cursing)ask for a 1/2  9/16 wrench that the numbers are engraved on said wrench. uglystupid2 Also tried to splain the difference between a common screw driver and a phillips head with a spectacular amount of non sucess!! crazy2 I had a lot of sucess with all my boys and one daughter on tool tutorials. cooldude And B T W-thanks fer reminding me how some stuff really do work. Grin RIDE SAFE.
« Reply #9 on: May 30, 2012, 08:55:45 AM »
Hey Bro, you will go to 7734 just as fast for lying as you will for stealin.
 cooldude cooldude tickedoff tickedoff crazy2 crazy2
I don't think there is a damn one of them that hasn't happened to me, especially the Drill Press.
YoungPUP
Valparaiso, In
« Reply #10 on: May 30, 2012, 02:44:46 PM »
 Evil Lips Sealed Evil
99 STD (Under construction)
