April 30, 2026, 12:40:04 PM
Texas Chapter
(Moderator:
Daniel Meyer
U joint......
Topic: U joint...... (Read 1420 times)
hotglue #43
U joint......
May 31, 2012, 04:28:01 PM »
needed to take the swingarm off.... so I rechecked the u joint, and it is showing a slight amount of end play.... I wouldn't think it would have any end play if the needle bearings were tight and not worn. Came in to order a new one from HDL, but got in too late.they were closed for the day... will call them in the morning to see if they have one.
blue=3 times
green=at least 4 times
5_19
Dublin, Texas
Re: U joint......
May 31, 2012, 05:18:41 PM »
Mark,
I agree, shouldn't be no end play. However when I checked out the new unit it had play also! I couldn't feel it as easy because the rubber bearing seals where a lot stiffer. It now has 20k miles on it and it appears to be fine. Last year at InZane "whats his name" the guy from California that rebuild u-joints showed a bunch of us how most off them fail. He showed us that the bearing needles freeze in the cups and the cup will start to rotate inside the yokes.
I believe if the cups are solid in the yoke and you feel a little play and the bearings are smooth it still can be used as a good back-up unit. When I helped Sixguns replace his the new U-joint had play also!! Honda must want it that way?
IBA # 45723
2009 BMW R1200 GSA
hotglue #43
Re: U joint......
May 31, 2012, 07:35:18 PM »
TJ, Mr Hay came to the rescue!!!!! he had a couple new u joints and brought one by ... that I will replace for him when the new ordered one comes in.
We were looking at it tonight, and one of the cups was rotating when we moved the joint. so a new one was definately in order!!!!
Thanks Jimmy!!!!!!! got the new part ordered!!!!!! U da Man!!!!!!!!!
blue=3 times
Mr.BubblesVRCCDS0008
Re: U joint......
June 01, 2012, 07:04:53 AM »
Mark you didn't pull the swingarm did you. I know you should know how to get it out without doing that.
Sparky51
Houston, TX
Houston, TX
Re: U joint......
June 01, 2012, 08:38:55 AM »
Way to go Jimmy! HG, et al, I have a spare too, just in case, for the next guy...
Glad you got fixed up in quick order!
