November 24, 2025, 01:23:23 PM *
Author Topic: head work............  (Read 1404 times)
spongebob
Alabama
« on: June 07, 2012, 06:42:02 PM »
Got an 2003 Std.......... have had about 3 different dyno runs on bike......... HP for mine is 87...... All the other stock ones I have seen has been in the low 90's to mid 90's...... But anyways, Has anybody had a dyno run stock....... then head work done and then re-dyno.... what increase did you get....... .... Thanks....
« Reply #1 on: June 07, 2012, 06:57:50 PM »
let me ask you this......if they lied and told you itwas 100hp would you be satisfied?
IF YES
Then be satisfied.........if shes running well, youll never miss what may be a somewhat innacurate reading anywas
« Reply #2 on: June 08, 2012, 09:16:15 AM »
Look under the swingarm and see if here's a charcoal canister. If so, you have a California bike. It has milder cams for better emissions. My CA Tourer has 87.8 HP and 88.3 FT/LBS of torque. Also altitude and temp and humidity can affect readings.
« Reply #3 on: June 11, 2012, 05:02:51 AM »
looks like the HP for cobra pipes.
Momz
ABATE, AMA, & MRF rep.
« Reply #4 on: June 11, 2012, 05:57:34 PM »
HP is a calculation based on RPM and Torque,
Not all dynos are calibrated the same.
Ambient temperature and humidity also play a large part in the dyno readings.
Yes head work could help,....but you'd need more than head work to see significant increases (like a supercharger).
« Last Edit: June 11, 2012, 06:01:16 PM by Momz » Logged
ALWAYS QUESTION AUTHORITY!
