April 01, 2026, 05:07:33 AM *
Author Topic: Clutch lever wear...  (Read 1716 times)
Daniel Meyer
The State of confusion.
« on: June 08, 2012, 09:53:57 AM »
Three places they wear…the pivot bushing in the lever, the plunger bushing wears on the outside, and then the plunger itself drills the hole in the plunger bushing deeper over time. These three wear points had reduced the “active” clutch action by nearly half.
Pretty sure this is my third one for wear. Broken several and lost one as well...  Undecided
CUAgain,
Daniel Meyer
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #1 on: June 08, 2012, 10:00:55 AM »
Lost one?! There must be really good story behind that one.   coolsmiley
Daniel Meyer
« Reply #2 on: June 08, 2012, 10:10:12 AM »
http://lifeisaroad.com/blog/2007/05/28/back-from-new-mexico/
CUAgain,
Daniel Meyer
« Reply #3 on: June 08, 2012, 10:12:41 AM »
Daniel was the result of the worn parts that the clutch had to be most of the waybout before the clutch would grab? I think the answer is yes, but you know more about it than I.
My rides:
Daniel Meyer
« Reply #4 on: June 08, 2012, 10:16:23 AM »
Other way around. Had to be hard against the bar to disengage and was beginning to drag even there.
CUAgain,
Daniel Meyer
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #5 on: June 08, 2012, 12:03:59 PM »
Always good stuff from/by you. Guess that's why I own all of your books.  cooldude
Six Guns
Fort Worth, Texas
« Reply #6 on: June 08, 2012, 12:49:51 PM »
That was a good run Daniel. You think that I would have seen your clutch lever fall off of your valk to the road as I was riding behind you, but I saw nothing but the wide open spaces as I was enjoying the ride home. I must admit that was a very good field repair you did on your valk to get you home.     cooldude
Daniel Meyer
« Reply #7 on: June 08, 2012, 01:01:44 PM »
Always a pleasure to ride with you!
CUAgain,
Daniel Meyer
Momz
ABATE, AMA, & MRF rep.
« Reply #8 on: June 08, 2012, 01:05:03 PM »
Daniel,....take the advise of a few HD HOG members.
Don't put too many miles on your bike; it lowers the resale value and causes more repairs. Grin
ALWAYS QUESTION AUTHORITY!
Six Guns
Fort Worth, Texas
« Reply #9 on: June 08, 2012, 01:10:55 PM »
Too late for that. LOL    uglystupid2
« Reply #10 on: June 08, 2012, 01:13:32 PM »
Resale value? You mean... someone would sell a perfectly functional bike??? Inconceivable!
(I keep using that word. It must not mean what I think it means...)
« Reply #11 on: June 08, 2012, 01:58:27 PM »
Princess Bride ( Inconceivable [ Montage ] )powered by Aeva
Master Blaster
Deridder, Louisiana
« Reply #12 on: June 08, 2012, 04:10:14 PM »
Used to post every year for everyone to pull the clutch lever,clean and lube for the upcomming riding season.  A cheapquickie that pays off big.
bentwrench
Philadelphia,Pa.
« Reply #13 on: June 08, 2012, 04:59:42 PM »
Yep,once a year a little bel-ray and mine shows no wear at 80k.
bw
Michael K (Az.)
Glendale, AZ
« Reply #14 on: June 08, 2012, 05:43:03 PM »
Little brass bushing is ovaled in mine Big BF did some grinding and fiddling with the doo-hickey that allows me to start the bike while in gear, clutch in. It wasn't doing it's job but I just lazily would kick it in neutral. Work around's my specialty! Bet you guys didn't think I even knew those fancy mechanichin words! Grin Grin
RP#62
Gilbert, AZ
« Reply #15 on: June 08, 2012, 06:35:19 PM »
bw
+1
Daniel Meyer
« Reply #16 on: June 09, 2012, 08:07:52 PM »
What's a riding season? Smiley
CUAgain,
Daniel Meyer
Alien
Ride Safe, Be Kind
Earth
« Reply #17 on: June 09, 2012, 08:16:31 PM »
Exactly! cooldude
Daniel Meyer
« Reply #18 on: June 11, 2012, 03:07:23 PM »
On the "why they wear" front...
Got curious...counted this morning...22 miles. Used clutch lever 127 times (more or less).
Dallas commute...on the throttle or brakes...not much in between...I am an aggressive downshifter...
CUAgain,
Daniel Meyer
