December 31, 2025, 06:11:03 PM *
Author Topic: Final drive fluid  (Read 2677 times)
kirkafied
States on the bike
Salt Lake City, UT.
« on: June 08, 2012, 08:35:00 PM »
  Did my first final drive fluid change around 17k. Being im pushing 50k now thought it my be time again. Drain plug no problems. Fluid came out and looked quite good. After removing the exhaust from the headers to get a good bite on the fill plug. Glass packs r  in the way to do this job without removing the exhaust or at least disconnecting. All is going well except now the fill plug is really seazed in there. I ended up striping the plug so bad even a bolt extractor wont get it out. My last resort is leaning her on the engine gaurd and adding the 5.1oz of fluid thru the drain hole. It worked without any problems. Can anyone think of a reason why this is a bad idea other then obvious half assed nature of doing it this way  uglystupid2? Anti seaze is my freind!!!!
tank_post142
south florida
« Reply #1 on: June 08, 2012, 08:38:02 PM »
pull the rear end to do a full service on the rear end. it's much easier to deal with on a work bench.
I got a rock Sad
VRCCDS0246
« Reply #2 on: June 09, 2012, 05:55:48 AM »
If you use synthetic gear oil, you can leave the oil in there as long as any tire lasts.....therefore doing what Tank said will be perfect.  Change the lube when the final drive is off the bike.
And another thing.  NO anti sieze on that fill plug, you dont want any of that stuff contaminating the small amount of oil in there........it wont corrode.  JUST DONT GORRILLA GRIP IT!!!  It has an o-ring so finger tight will probably do and just a tad over that with the socket wrench is all it needs.  People crank on that thing and then find out its made out of fake metal and cant take any torque
« Last Edit: June 09, 2012, 06:00:44 AM by Chrisj CMA » Logged
whitestroke
San Pedro, Ca.
« Reply #3 on: June 09, 2012, 07:50:07 AM »
Is the fill plug the chrome cap I see at the top of the last picture?
If so is that just a cap with a screw underneath it?
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
RP#62
Gilbert, AZ
« Reply #4 on: June 09, 2012, 07:51:49 AM »
That's the vent and its pressed in.  No need to ever mess with it.
-RP
redflash
Southern New Hampshire
« Reply #5 on: June 09, 2012, 07:52:39 AM »
that chrome cap is the breather, keeps water out too...
tank_post142
south florida
« Reply #6 on: June 09, 2012, 08:16:05 AM »
he is pouring the lube in the fill plug hole. the bolt closest to you is the drain plug.
I got a rock Sad
VRCCDS0246
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #7 on: March 02, 2013, 04:54:58 PM »
I change my final drive oil every time I change my engine oil. Takes such a small amount & we all know that is how the drive shaft pinion cup is lubed...good insurance....IMO
Any coward can fight a battle when he's sure of winning; but give me the man who has pluck to fight when he's sure of losing.
GEORGE ELIOT
Brian
Monroe, NC
« Reply #8 on: March 03, 2013, 04:24:55 AM »
I do the same Mallett. As well as every spring the rear end comes off for spline maintenance, maybe just a piece of mind knowing when the good weather comes around my driveline is in good working order. That small amount of fluid will not put me in the poor house. The exhaust pipe on that side does not have to be removed. When using the atv lift the shocks are the only thing that needs disconnected. I personally loosen the exhaust verses setting up the lift as I check all the header acron nuts anyway.
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #9 on: March 03, 2013, 05:30:13 AM »
Brian, I don't remove anything...I have a small rubber hose I attach to a funnel & pour my oil in that way....easy
GEORGE ELIOT
Brian
Monroe, NC
« Reply #10 on: March 03, 2013, 05:27:07 PM »
If leaving it on the sidestand are you pouring in the measured amount?
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #11 on: March 03, 2013, 05:42:11 PM »
Yes Brian, I pour in 5.1 ozs in a measuring cup then pour it in...
GEORGE ELIOT
DIRKDEE
« Reply #12 on: March 30, 2019, 02:10:56 PM »
hello, i drained the my diff today, 6 oz of black fluid came out, how many oz do I put back  ??
« Reply #13 on: March 30, 2019, 03:55:53 PM »
I fill with the differential upright, (or bike upright) . I fill till it starts to come out the fill hole. Not very scientific, but it works. Don't over tighten the fill cap. It will crack fairly easily.
DIRKDEE
« Reply #14 on: March 30, 2019, 04:01:20 PM »
SUPER BIG THANKS.  HAPPY TRAILS
« Reply #15 on: March 30, 2019, 04:26:47 PM »
Also, I recommend synthetic gear oil.
« Reply #16 on: March 31, 2019, 05:06:01 AM »
+1. Been a fan of this method for years
« Reply #17 on: March 31, 2019, 05:09:47 AM »
Post a picture of the stripped fill plug, I may be able to help you get it off
« Reply #18 on: March 31, 2019, 05:53:21 AM »
These resurrections can trick one. (It was 7 years back)  Wink
« Reply #19 on: March 31, 2019, 09:47:11 AM »
Ya. I didn't look closely enough. I thought it was a new response to an old post
