March 09, 2026, 05:16:30 PM *
Author Topic: ........for things that go *bump* in the night..  (Read 3586 times)
~ Timbrwolf
Northern Michigan VRCC # 8533
« on: May 28, 2009, 07:18:48 PM »
...just picked this up tonight....Mossberg 500 ....collapsable stock....6 shot..
....sposed to load 5 shells....and one in the chamber....can only get it to accept 2 shells for some reason....going back tomorrow to find out why..
....been wanting something for a little home protection....think this,ll do the trick..
« Last Edit: May 28, 2009, 07:21:03 PM by ~ Timbrwolf » Logged
alph
Eau Claire, WI.
« Reply #1 on: May 28, 2009, 07:28:50 PM »
just be careful and know what you'll be shooting, and beyond!  as for having a riffle, get a gun also!!!
gregc
Media Pa.
« Reply #2 on: May 28, 2009, 07:30:02 PM »
  Check to see if they left a dowel in the shell tube, it is placed in there to limit the shells you can load when hunting.  Undo the knurled knobthat holds the barrel to the reciever, remove the barrel, then remove the split ring that holds the front grip in place, you can now get into the shell tube and remove the dowel.  Watch there is a rather long spring that will come out before the dowel.
« Reply #3 on: May 28, 2009, 07:38:43 PM »
What Greg said, there's gonna be a wooden dowel in the tube that's in there so the gun's legal for hunting... Pop that dowel out and you'll be good...
I had one of these by the bed until the little one came along... Now I've got a pistol in a beside the bed safe...
Also just picked up a Saiga-12... WONDERFUL toy! AK47 in 12 gauge shotgun... I've got a 13 round mag + 1 in the pipe... If 14 rounds of 12 gauge as fast as you can pull the trigger won't get your point across, you've got bigger problems!
Congratulations on a FINE home defense gun!
hotglue #43
« Reply #4 on: May 28, 2009, 07:45:10 PM »
Yep... pull the plug.... should be good for 5
 blue=3 times
 green=at least 4 times
PAVALKER
Pittsburgh, Pa
« Reply #5 on: May 28, 2009, 07:45:53 PM »
I have a Remington 870 18in Barrel PD black pump, but my mag tube is full length, laser pointer at the end of the tube and a flashlight haning below.  Mine holds 8 I believe,  first 2 are #6/7 shot then 4 - 00 Buck and finally 2 deer slugs for the grand finale if they get too far out the door.
John
~ Timbrwolf
« Reply #6 on: May 28, 2009, 07:48:25 PM »
....okay guys....wait
.....what yer saying is...unscrew that cap on the end of the "load tube"...underneath the barrel...pop the spring inside...and the dowel should slide out ?
.....sorry for the questions...ive owned a few hand guns....but this is my first shot gun...
.......thanks for you help
« Reply #7 on: May 28, 2009, 08:02:05 PM »
Unscrew the knob on the end of the feed tube. Wrack the action open (Make sure it's unloaded too) and the barrel should separate from the the receiver and feed tube. Set the barrel aside, point the receiver/feed tube at the ground and jiggle it, the wooden dowel should fall out of the screw hole that you just removed the screw from...
Once it drops out, line the barrel back up onto the receiver and it should more or less drop back into place, hand tighten the knob back in place to screw the barrel back onto the receiver, and voila!
« Reply #8 on: May 28, 2009, 08:03:49 PM »
They go WAAAAAAY further then you need to go for this, but this should help some:
Mossberg 500 Disassemblypowered by Aeva
« Reply #9 on: May 28, 2009, 08:04:53 PM »
Not quite as slick of a video, but this guy's just doing the dowel removal procedure:
Mossberg 500 extra shells Tippowered by Aeva
Ben
Abilene TX
« Reply #10 on: May 28, 2009, 08:21:46 PM »
Wolf, try turning the extra shells in the butt stock shell holder upside down, you may find that they handle much eaisier ,especially because your shot gun loads thru the bottom...
Nice weapon!!
~ Timbrwolf
« Reply #11 on: May 28, 2009, 08:25:42 PM »
......Got it Serk....thanks !
....unscrewed  the end cap...pulled the barrel out just a little...then up....turned the load chamber down....shook it a little...and viola....out slid a super thin 6 inch dowel....push the barrel back in...screwed the end cap back in....racked her a few times...loading a live one...(safety on)......then ejecting the live load and loading a 2nd.....shes loaded and ready....
..........thanks bro
« Reply #12 on: May 28, 2009, 09:11:48 PM »
Sweet, glad I could help!!!
I'm actually more OCD about guns than I am about bikes (Or saltwater reef aquariums, my other big obsession)...  Roll Eyes
Normandog
« Reply #13 on: May 29, 2009, 04:10:05 AM »
on changing the stock to a pistol grip type. Makes a nice home defense weapon.
~ Timbrwolf
« Reply #14 on: May 29, 2009, 05:33:17 AM »
.....Thanks Norman....been waiting for the price to go down for 3 years....it went up....so I figgered it was time to get it.....Ive researched it online and you,re right....there are alot of "mods" available for this particular gun...
~ Timbrwolf
« Reply #15 on: May 29, 2009, 05:34:35 AM »
......thats cool Serk....we,ve talked about getting a fish tank....I always wanted to get a salt water setup...are they as hard to maintain as Ive heard ?
Bagger John - #3785
« Reply #16 on: May 29, 2009, 06:19:45 AM »
I'm looking at one of these. The Picatinny rail on the receiver comes in handy when considering rear sight options. I prefer an ACOG/laser combo for CQB situations.
~ Timbrwolf
« Reply #17 on: May 29, 2009, 07:50:54 AM »
......what ever THAT means...lol
.....my next question John is.....ammunition.
....bought this gun from a sportings good store...and the guy that sold it to me, obviously wasnt too knowledgeable.....seeing as he told me it was a 5 shot...and when I got it home I read on the outside of the box that it was a....six shot..
....I asked him about ammo differences and he replied that some cost 13 bucks...some 30 bucks......I said..no...I meant differences in pattern...power...etc....he wasnt too informative....he directed me to double 00  .....which I bought....I asked him if it would cut through a wall if need be....and he said yes..    ....this was the 13 dollar ammo..
....can enlighten me some on what would be suitable for this particular gun ?
Bagger John - #3785
« Reply #18 on: May 29, 2009, 08:04:47 AM »
ACOG - Advanced Combat Optical Gunsight - self-illuminating; requires no batteries. The one shown here has a Docter Optic battery-powered red dot mounted to it for those "point and shoot" scenarios:
"CQB" stands for Close Quarter Battle - or 'mixing it up in a telephone booth', as such a fight is occasionally referred to.
2 3/4" length ('standard'), 00 buckshot loads will give you 6 round capacity.
3" length ('magnum'), 00 buckshot loads will give you 5 round capacity.
For home defense - a human-mass target at under 30yds - I would go with the 2 3/4" version. The extra power probably won't be needed but the extra round could come in handy. Winchester and Remington both offer an affordable, decently performing loading of such.
« Reply #19 on: May 29, 2009, 09:12:38 AM »
IMHO 00-Buck in 2 3/4 rounds is more than adequate for home defense...
And, sorry to go off topic, but you did ask... Smiley IF you do your homework saltwater isn't any harder than other aquariums... And saltwater fish only isn't terribly more expensive... Once you get into reef (Corals, anemones, etc) the cost and work go WAAAAAY up FAST...
This is my tank with the cover up, you can see into the fish room... I've got I'm guessing 3-4 nicely set up Valkyrie Interstates in this tank cost wise... Like I said, I tend to be a bit OCD about my hobbies... Wink
Few random close up pics just 'cause I love showing my critters off...
If you ever get serious about setting up a saltwater aquarium, hit me up... Getting me to talk about 'em is easy, the hard part is getting me to shut up about it!  angel
Duey
Rochester, MN
« Reply #20 on: May 29, 2009, 11:22:32 AM »
This is the actual shotgun course > http://www.remington.com/safety/online_courses/movie.htm
If that doesn't work or you want to see other courses go to this site > http://www.remington.com/
Go to the safety section and check it out. Good Luck and Enjoy!
Evil One
Buena Vista Va, 24416 USA
« Reply #21 on: May 29, 2009, 03:05:05 PM »
Great choice on the home defense weapon.
I have a Mossy 500 as well, but what stays by my bed is this.
12 gauge double barrel coach gun. Very compact yet with full length stock.
Also NOT something a person wants to be face to face with.
For ammo, what "I" use... and suggest, is Centurion Multi-Defense Buck... also known as Buck and Ball.
It is a .650" lead ball and 6 #1 buck pellets.
BRUTAL ammo, and since its 2 3/4 its very manageable.
My wife keeps a Benelli 121 M1 semi auto with 7 rounds of buck and ball on her side of the bed.
I have been questioned about only having 2 rounds... I dont know anyone who will keep coming with both rounds in them... and I have my 1911 as backup... and my wife backing THAT up. Cheesy
Jim
Psychotic Bovine
New Haven, Indianner
« Reply #22 on: May 29, 2009, 05:33:35 PM »
and, last but not least:
Yes, always be prepared.  For anything.
"I aim to misbehave."
RP#62
Gilbert, AZ
« Reply #23 on: May 29, 2009, 05:53:35 PM »
Great pics Serk thanks.  I especially liked the percula. I used to have  55 gallon and 30 gallon salt water tanks and they were much less work than the little 10 gallon freshwater tanks I started with.  I won't say I was ate up, but I used to have occasional business in Hawaii and when I was on the way to the airport for the trip home, I used to stop at a small shop there, buy 4 or 5 butterflies and triggers (they were $5 there) and bring them back in carry on bags.  Used to do the same thing on trips to the keys.  I'd go snorkeling, catch a bunch of damsels, sergeant majors, top hats, etc., bag 'em and top the bags off with oxygen, then pack them in a cooler and ship them through baggage.
-RP
-RP
Bagger John - #3785
« Reply #24 on: May 29, 2009, 06:35:39 PM »
Someone mentioned "zombies"?
FLAVALK
Winter Springs, Florida
« Reply #25 on: May 29, 2009, 07:06:41 PM »
I prefer to keep one of these by the bed   Evil
Woman (gasp) shooting an M-4powered by Aeva
« Last Edit: May 29, 2009, 07:25:08 PM by FLAVALK » Logged
Evil One
« Reply #26 on: May 29, 2009, 07:23:50 PM »
Not much for women shooting pop guns...
But I DO like my wife makin craters with my .44 magnum.  Grin
Jim
« Last Edit: May 30, 2009, 10:32:14 AM by Evil One » Logged
« Reply #27 on: May 30, 2009, 07:19:03 AM »
Hehehe, if ya' like women shooting poodle poppers (Yes, I know I've posted this pic before, I'm a proud daddy!) how about a six year old shooting an AR-15? (My daughter...)
RP - Glad ya' liked the pictures... I keep meaning to start a "So, what are your OTHER interests/hobbies/obsessions" thread here so I can go on and on and on about my guns, fish tanks, Renaissance faires, etc...
