robin
Get on it and RIDE!!
Hardwick NJ
« on: June 10, 2012, 07:03:06 AM » |
Anybody use any of the kits out there for restoring your milky lights give me some feed back if ya please
« Reply #1 on: June 10, 2012, 08:10:24 AM » |
You take the kit, follow the instructions and about 1/2 to 3/4 of an hour later, the lens is bright and shiny.
6 months down the line and it is foggy again.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #2 on: June 10, 2012, 08:22:15 AM » |
I could save you some money...400grit, 600grit, 1000grit wet sand. Fine polishing compound for light scratches to heavy oxidation by hand. Then buff with the same product and a powerball. Then I buff with a polish. I just did my truck last week and am doing my wifes truck as we speak, came in for a break from the heat.
YoungPUP
« Reply #3 on: June 10, 2012, 09:00:36 AM » |
Just did the 3m kit on my Grd Cherokee (advanced auto parts about $30). Only tip I have over the kits instructions is us water for all 3 of the 4 steps, (didn't trust the hot plastic smell doing it their way) WAX it when you're done. Came out Way better then it was but never will be as good as original again.
99 STD (Under construction)
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #4 on: June 10, 2012, 09:32:37 AM » |
Did the 'Turtle Wax' version, on my sons '03 Subaru WRX, and after 1/2 hour the lenses looked new... As previously stated, ya might need to re-do. His are starting to get a bit hazy, and it's been about 2 years now.
Black Dog
Just when the highway straightened out for a mile And I was thinkin' I'd just cruise for a while A fork in the road brought a new episode Don't you know... Conform, go crazy, or ride a motorcycle...
« Reply #5 on: June 10, 2012, 11:00:47 AM » |
Toothpaste and a brush or rag.
gregc
« Reply #6 on: June 10, 2012, 11:48:23 AM » |
Don't need the kit, get a sheet of 1000, 1500, and 2000 grit wet sand paper. The buy some plastic polish, and a buffer pad for a drill. Use lots of water when sanding, the first grit is the toughest to break thru all the oxidation. Then follow up with the next 2 finner grades , and polish to a clear finnish. Wax will help to keep the gloss.
Tropic traveler
Silver Springs, Florida
« Reply #7 on: June 10, 2012, 12:26:27 PM » |
+1 on the method, it works. What you are doing by sanding/polishing the yellow off the headlamps is removing the original protective coating which has gone bad. Once polished clean there is no coating left & the lens turns yellow quicker than with the OE coating. Regular polishing with wax can help it last but never as long as the original. Funny thing is I have a 2000 Ranger & the lamps still look like new, never touched them. I have seen many other same age & newer Rangers with badly yellowed lens. ??? Go figure. My 2003 Sable has to have the procedure Tundra descibed done about once a year since the first time.
'13 F6B black-the real new Valkyrie Tourer '13 F6B red for Kim '97 Valkyrie Tourer r&w, OLDFRT's ride now! '98 Valkyrie Tourer burgundy & cream traded for Kim's F6B '05 SS 750 traded for Kim's F6B '99 Valkyrie black & silver Tourer, traded in on my F6B '05 Triumph R3 gone but not forgotten!
Black Dog
VRCC # 7111
« Reply #8 on: June 10, 2012, 08:29:35 PM » |
Very true... The kit I used had a 'seleant' that was painted on the lenses, after the restore job had been done. Maybe that is why it has lasted so long.
Black Dog
« Reply #9 on: June 10, 2012, 08:34:53 PM » |
Have used rubbing compound with a buffer, didn't take long. A buddy and I both did this, I waxed mine, he clear coated his with rattle can clear coat. I have to admit, his still look good.
VRCC# 29981 Learning the majority of life's lessons the hard way.
X Ring
VRCC #27389, VRCCDS #204
« Reply #10 on: June 10, 2012, 11:35:17 PM » |
You can also buy protective film to put on your headlights and turn signals. You can get it precut or in 24x24" sheets.
Marty
joefromperry
« Reply #11 on: June 11, 2012, 05:45:08 AM » |
I recently read in at least two places (consumer reports? popular mechanics?) that the Sylvania kit was way above the others in results and didn't require a drill. I just bought the kit, but haven't used it yet.
2000 Honda Valkyrie Interstate Silver/Blue 2002 Honda Shadow ACE Deluxe 1972 Honda CL350K4 Scrambler 2008 Ural Patrol 1987 Honda Rebel 450
