November 24, 2025, 11:54:53 AM *
Author Topic: Dan Marc install ?????  (Read 1061 times)
CASABROKER
« on: June 11, 2012, 01:16:43 PM »
Has anyone install a Dan Marc from the left side only?  I have custom engine hangers.  The one on the right is a paint to remove the ignition is tied into it.  The one on the right is fairly easy to remove and gain access.  Let me know if so.
tank_post142
south florida
« Reply #1 on: June 11, 2012, 01:18:41 PM »
one would normally pull the tank to gain access to the fuel line and the electrical system.
I got a rock Sad
VRCCDS0246
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: June 11, 2012, 01:28:41 PM »
^ This.
Marty
« Reply #3 on: June 11, 2012, 04:12:27 PM »
Most definitely. If you're going to do it, do it right....which precludes doing it from the outside like you describe. Probably will need to pull the airbox as well, you want to be certain all fuel lines run "downhill" from the petcock or you'll experience starvation...especially with a low fuel level.
