February 05, 2026, 06:24:19 AM *
Author Topic: 2 relays for a Blinker Buddy?  (Read 1431 times)
SpidyJ
Murrells Inlet
« on: June 12, 2012, 11:00:17 AM »
So I guess I need a relay for each side to hook up the blinker buddy?
I have a 99 IS.  I thought there would be a single flasher for both sides that I could hook up directly to, like in a car, but I don't see one.
1999 Fast Black Interstate
Peace,
johnnywebb
JC
The Beast
Franklin, TN
« Reply #1 on: June 12, 2012, 11:41:54 AM »
Mine hooked directly between the orange and blue wires. No relays should be needed.
SpidyJ
Murrells Inlet
« Reply #2 on: June 12, 2012, 12:28:46 PM »
So one side of the buzzer hooks to the orange and the other to the blue?
I wonder where it's getting the ground?
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #3 on: June 12, 2012, 05:23:45 PM »
Well, you are correct...it works perfectly w/o relays.  Must be a secret ground wire somewhere.
Peace,
johnnywebb
JC
The Beast
Franklin, TN
« Reply #4 on: June 13, 2012, 10:15:03 AM »
It's FM.
GJS
Today is the tomorrow you worried about yesterday.
Vancouver Island, BC, Canada
« Reply #5 on: June 13, 2012, 02:43:39 PM »
FM MyA.  coolsmiley
When one side is hot, the other is not.
The vibrator operates off the difference between the two.
So each side sometimes as acts as a quasi ground, even though its not.
If you want to use a proper ground, then you can use two small diodes. One for each signal wire, tied together and connected to one side of the vibrator. The other wire goes to ground. This way you can add a small relay triggered by your brake light.
With the brake light triggered relay, when you have the brake on, the blinker buddy looses it's ground line, stopping buzz bottom while stuck in intersections!
Good luck
Glenn
ps. I have done this on my Interstate and it works nicely. cooldude
The tragedy of life is not that it ends so soon, but that we wait so long to begin it.
- W. M. Lewis
tank_post142
south florida
« Reply #6 on: June 13, 2012, 03:30:54 PM »
the turn bulb in the headlight is wired the same. just the two hot wires , no ground.  uglystupid2
I got a rock Sad
VRCCDS0246
SpidyJ
Murrells Inlet
« Reply #7 on: June 14, 2012, 12:06:17 PM »
FM MyA.  coolsmiley
Good luck
Glenn
Thanks Glenn,
Great explanation..........a pseudo ground!
I will see how bothersome the buz butt is b4 installing the diodes and relay but that sounds like a very good setup.
This site is so nice.........."No Fear" Valkyrie Repairs!  Cool
Peace,
johnnywebb
