February 05, 2026, 06:24:16 AM *
Author Topic: Bleeding Brakes and Clutch  (Read 1306 times)
Shotgun
Canadian Lakes, Michigan
« on: June 14, 2012, 02:16:35 PM »
Been a while since I bled the brakes and clutch.  I have Speedbleeders so it makes it easy.  One question though, is all brake fluid synthetic?  I picked up some Dot 4 and it says synthetic but I thought I read somewhere that I can't use synthetic.....that may be Dot 5 though.....any help?
« Reply #1 on: June 14, 2012, 02:56:24 PM »
DOT 4 synthetic is good. You don't want to use silicone.
Shotgun
« Reply #2 on: June 14, 2012, 03:45:16 PM »
Thanks.......I knew that.....at my age it takes a little to shake up the memory.
« Reply #3 on: June 14, 2012, 09:01:48 PM »
Wasn't there also something about not mixing DOT 4 with other DOT types?
