April 01, 2026, 08:13:03 AM *
Author Topic: Need Some Computer Help  (Read 810 times)
BIG--T
The Twilight Zone
« on: June 15, 2012, 06:47:39 AM »
I have tried to download the Valkyrie manual several times without success. I don't know if its  bad link or on my end. I downloaded the newest version of Adobe reader but that didn't help.
This is what it said:
" Adobe reader could not open because it is either not a supported file type or because the file has been damaged( for example, it was sent as an email attatchment and wasn't correctly decoded."
I'm not too computer savvy so hopefully someone will know what this means.
Thanks, Tony
Jess Tolbirt
White Bluff, Tn.
« Reply #1 on: June 15, 2012, 06:55:42 AM »
right click on the link and do a save as..
then try to open it, dont try to open it directly,,,
if that doesnt work shoot me an email and i will send you a cd of it...
Valkyrie member # 23084
bigguy
VRCC# 30728
Texarkana, TX
« Reply #2 on: June 15, 2012, 07:27:42 AM »
+1 on Jess's right click suggestion. Also keep in mind that it will take some amount of time to finish downloading and you won't be able to open it until it does. If your system shows the icon immediately after you select "save as," and you try to open it before the download finishes, you will also get a "damaged file" type of message. Give it a few minutes before you try to open it. Finally, don't close your browser window before it finishes.
Here there be Dragons.
Jess Tolbirt
White Bluff, Tn.
« Reply #3 on: June 15, 2012, 07:34:18 AM »
have you tried this page? http://www.valkyrienorway.com/download.html they are in a zip file and you will have to unzip them to be able to read them.. use something like winzip
BIG--T
The Twilight Zone
« Reply #4 on: June 15, 2012, 08:06:51 AM »
Yes I did it just as you said and nothing!  Sad
BIG--T
The Twilight Zone
« Reply #5 on: June 15, 2012, 08:08:39 AM »
Yes, hubcapsc/Mike sent me that link and the results are the same.  Undecided
« Reply #6 on: June 15, 2012, 09:52:39 AM »
I just downloaded it, unzipped it, and opened it in both Mac OS X and Windows XP without issue.
BIG--T
The Twilight Zone
« Reply #7 on: June 15, 2012, 09:56:31 AM »
Well there is something wrong on my end. Thanks
Pete
« Reply #8 on: June 15, 2012, 10:45:24 AM »
Make sure the extension name is   .PDF   .
