November 19, 2025, 07:41:28 AM *
Author Topic: K&N air filter  (Read 2397 times)
Youngsmoke
Las Vegas, NV
« on: May 29, 2009, 10:54:20 PM »
hey all,
  Just bought a new, to me, 1998 valk tourer.  I want to do a full tune up for 2 reasons. 1) even though it seems like the previous owner too good care of my new baby, I did not get records from him, so I am not sure about specific dates that services were preformed.  2) I have about 50K (actually 49.3k) and so I am just about due for most of the services.  One of the things that I am planning on doing is replacing the air filter.  I am wondering about the possible advantages of upgrading to a K&N air filter.  Having priced them out, the OEM is like $24 but I found the K&N for $53, so price is not a factor to me, I am just concerned about any problems with the K&N.  My mechanic friend has told me to stick with OEm because he says that the k&n will let too much junk through.  is this the case?  Have any of you switched to the K&N and regretted it?  at this point I don't plan on upgrading the pipes, is this a problem with a high flow filter?
thanks for the advice
Ari cooldude
« Reply #1 on: May 29, 2009, 11:41:42 PM »
I have run a K&N filter for many many miles and no problems.     IMHO the K&N has the OEM filter beat all to 7734 on filtering dirt out....  Plus it is recleanable and can be reoiled as needed.......
I did not use the pre filter that comes in the kit.
I did raise the nose of the tank up about a 12/" to let more air in.....
Youngsmoke
Las Vegas, NV
« Reply #2 on: May 29, 2009, 11:47:08 PM »
you lifted the nose of your tank up a foot?  is that correct?  I would love to see pics of that, because I can't comprehend how you could have lifted it that much?!?
Brad
Reno, Nevada
« Reply #3 on: May 30, 2009, 12:13:37 AM »
he ment a half inch
Youngsmoke
Las Vegas, NV
« Reply #4 on: May 30, 2009, 01:52:31 AM »
that makes a lot more sense, thnks.  don't know how i didn't see that uglystupid2
John U.
Southern Delaware
« Reply #5 on: May 30, 2009, 05:52:07 PM »
An air filter study of oem and a variety of other paper and oiled filters including K&N on the Diesel Place web site showed that the K&N did let much more dirt pass. If you hold one up to a light or the sun you will see a great many points of light. If the light has a straight path so does dirt.
The study also showed that the K&N caused less pressure reduction downstream of the filter, meaning it is less resistant to air flow. These results assume the K&N is properly oiled.
So you have to decide what's important to you.
MP
North Dakota
« Reply #6 on: May 31, 2009, 05:14:48 AM »
In other words, you can flow dirt and air, or keep the dirt out.
In some apps, the OEM filter is so restrictive, that a K&N really helps out.  In comparing the two filters in a valk, there seems to be little difference, so I stick with OEM.  Also, the K&N needs to be pulled and cleaned, and it is to be changed out after a while anyway.  It is more expensive to have the K&N, unless you run like 30,000 miles a year.
MP
"Ridin' with Cycho"
redflash
Southern New Hampshire
« Reply #7 on: May 31, 2009, 06:14:30 AM »
I put K&N in every gas-burning thing I own. They flow more air, keep crap out and cost less in the long run to own/maintain. Honder gets a lot of dough for a disposable paper filter, where the K&N will last easily 100,000 miles. I have 215,000 on one in my Explorer. Bought ONE, not hundreds of dollars worth of throw-away filters. If you know of anyone who has "worn out" a K&N, let me know about it! I do use the prefilter on my Valk, fyi.
