November 24, 2025, 01:32:51 PM *
Author Topic: Question re. Hoppy convertor.  (Read 889 times)
« on: June 21, 2012, 04:11:35 PM »
I have a model #48845 Hoppy but no instructions. It has four wires on one side labeled; white=grnd, brown=tail, yellow=l turn,  green=r turn.
The other side has five wires labeled the same with an extra wire; red=brake.
My dilema...which is the input side and which is the output side? I've looked on their website but it doesn't specify input/output.
chrise2469
Winnipeg Manitoba Canada
« Reply #1 on: June 21, 2012, 04:15:29 PM »
the 5 wires are the input (hooked to the bike) the four wires are to the trailer.
link to instructions
http://www.outdoorpros.com/pdf/Hoppy_48845.pdf
link to hoppy webpage with pdf
http://www.hopkinstowingsolutions.com/products/vehicle-wiring-connectors/taillight-converters/tail_light_converter_12.html
« Last Edit: June 21, 2012, 04:19:34 PM by chrise2469 » Logged
« Reply #2 on: June 21, 2012, 05:00:48 PM »
Thanks Chrise, I'm going to use it to hook up my turn signals in back. I now have them set up to work as a three way; run, turn, brake. But, the brake function quite working and it's been so long since I did the wiring I don't recall what/how I did it. Using this Hoppy will simplify things a lot. I already have real bright LED's in back with dual brilliance so I'll have to do a little experimenting I think since they have two wires; one for run, one for turn/brake. I'm not even certain this particular model will work so if someone has experience with this(two wires plus ground), please speak up. Might save me a burned out LED...or worse.
