November 24, 2025, 01:49:29 PM *
Author Topic: Mixing oil grades  (Read 1587 times)
Thulsa Doom
Rhode Island
« on: June 23, 2012, 04:00:53 PM »
Let me start by saying that the local Walmart has a poor selection of oils. Seems all they carry is 5w20, 5w30 and 10W30 in the synthetic.
I walked in looking for plain old 10W40 synthetic and walked out with Rotella T6 5W40.
I figured the 5 would be alright on startup. Right or wrong?
Anyway, 1/2 way though the change I spilled 1/2 the bottle so at this time my Valk sits with only a couple of quarts in it. It looks like I'm going to have to go back out and buy some more oil before I can run it again, though I may not go all the way back to Walmart.
Is there any reason to think that it's not ok to mix the 5w40 that's in it with whatever else I can find? 10w30, 15w40, etc?
... and as I shifted into second I couldn't remember a thing she said.
« Reply #1 on: June 23, 2012, 04:16:09 PM »
Mixing of oils is no problem as long as both oils are compatable for the bike. Try to get a 10W or 15W as 5W is a bit thin for the Valk. The thinner oils are for newer engines where the bearing clearances are tighter and they're trying to maximize MPGs in cars.
Thulsa Doom
Rhode Island
« Reply #2 on: June 23, 2012, 09:26:35 PM »
She's all topped off with 15W50. I'm confident that will be fine. cooldude
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #3 on: June 24, 2012, 05:45:19 AM »
Many use only the Mobil1 15/50, as it seems to quiet down the tranny noise
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: June 24, 2012, 06:33:05 AM »
I think some folks misunderstand what the multi-viscosity numbers mean. I will copy and paste an article I found VERY educational. I am NOT affiliated with any oil company. The direct link will be at the bottom of my post. I would NOT recommend mixing oil of different viscosity simply because oils of different weights will not mix, but will stay as two separate fluids. The original page (link at bottom) is easier to read.
Motor Oil Viscosity Grades
What does the SAE Viscosity rating on your Motoroil bottle mean?
How do they come up with this rating . . .really?
Most of the time when viscosity is explained words are used that are too technical for the average person to quickly grasp. This leaves them still wondering what the viscosity numbers really mean on a bottle of motor oil. Simply put, viscosity is the oil's resistance to flow or, for the layman, an oil's speed of flow as measured through a device known as a viscometer. The thicker (higher viscosity) of an oil, the slower it will flow. You will see oil viscosity measurement in lube articles stated in kinematic (kv) and absolute (cSt) terms. These are translated into the easier to understand SAE viscosity numbers you see on an oil bottle.
OK . . .What does a 5W-30 do that an SAE 30 won't?
When you see a W on a viscosity rating it means that this oil viscosity has been tested at a Colder temperature. The numbers without the W are all tested at 210° F or 100° C which is considered an approximation of engine operating temperature. In other words, a SAE 30 motor oil is the same viscosity as a 10w-30 or 5W-30 at 210° (100° C). The difference is when the viscosity is tested at a much colder temperature. For example, a 5W-30 motor oil performs like a SAE 5 motor oil would perform at the cold temperature specified, but still has the SAE 30 viscosity at 210° F (100° C) which is engine operating temperature. This allows the engine to get quick oil flow when it is started cold verses dry running until lubricant either warms up sufficiently or is finally forced through the engine oil system. The advantages of a low W viscosity number is obvious. The quicker the oil flows cold, the less dry running. Less dry running means much less engine wear.
SAE Viscosity Chart (High Temp)
100° C (210° F)
SAE
Viscosity
Kinematic
(cSt)
100° C Min
Kinematic
(cSt)
100° C Max
20    5.6    <9.3
30    9.3    <12.5
40    12.5    <16.3
50    16.3    <21.9
60    21.9    <26.1
Winter or "W" Grades
SAE
Viscosity
Low Temp (°C) Viscosity cP
Kinematic
(cSt)
100° C Min
Cranking
Max
Pumping
Max (NYS)
0W    3,250 @ -30    60,000 @ -40    3.8
5W    3,500 @ -25    60,000 @ -35    3.8
10W    3,500 @ -20    60,000 @ -30    4.1
15W    3,500 @ -15    60,000 @ -25    5.6
20W    4,500 @ -10    60,000 @ -20    5.6
25W    6,000 @ -5    60,000 @ -15    9.3
Obviously, cold temperature or W ratings are tested differently than regular SAE viscosity ratings. Simply put, these tests are done with a different temperature system. There is a scale for the W, or winter viscosity grades and, depending on which grade is selected, testing is done at different temperatures. See the Tables to the right below for more information.
Basically to determine non-winter grade viscosity using a viscometer a measured amount of oil at 100° C is allowed to flow through an orifice and timed. Using a table they determine SAE viscosity based on different ranges. Thicker or heavy viscosity oils will take longer to flow through the orifice in the viscometer and end up in higher number ranges such as SAE 50 or SAE 60 for example. If an oil flows through faster being thinner/lighter then it will wind up in a low number range such as SAE 10 or SAE 20 for example. Occasionally it is possible for an oil to barely fall into one viscosity range. For example, an oil is barely an SAE 30 having a time that puts it on the very low side. Then another oil is timed to be an SAE 20 on the high side not quite breaking into the SAE 30 numbers. Technically speaking these oils will be close to the same viscosity even though one is an SAE 20 and the other an SAE 30. But you have to draw the line somewhere and that's how the SAE system is designed. Another system takes more accurate numbers into account known as cSt abbreviated for centistokes. You'll see these numbers used often for industrial lubricants such as compressor or hydraulic oils. The table at the right, SAE Viscosity Chart (High Temp), shows the equivalents for cSt and SAE viscosity numbers. You'll see the ranges for cSt compared to SAE numbers. An oil that is 9.2 cSt will be nearly the same viscosity as an oil that is 9.3 cSt, yet one is an SAE 20 and the other is an SAE 30. This is why the cSt centistokes numbers more accurately show oil viscosity.
Now if you look at the table labeled Winter or "W" Grades, you can get valuable information on how the W or winter grade viscosities are measured. Basically, as shown by the chart, when the oil is reduced to a colder temperature it is measured for performance factors. If it performs like a SAE 0 motor oil at the colder temperature, then it will receive the SAE 0W viscosity grade. Consequently, if the motor oil performs like a SAE 20 motor oil at the reduced temperatures (the scale varies - see the chart), then it will be a SAE 20W motor oil.
If a motor oil passes the cold temperature or W (winter grade) specification for a SAE 15W and at 210° F (100° C) flows through the viscometer like a SAE 40 motor oil, then the label will read 15W-40. Getting the picture? Consequently, if the motor oil performs like a SAE 5 motor oil on the reduced temperature scale and flows like a SAE 20 at 210° F (100° C), then this motor oil's label will read 5W-20. And so forth and so on!
I can't tell you how many times I have heard someone, usually an auto mechanic, say that they wouldn't use a 5W-30 motor oil because it is, "Too thin." Then they may use a 10W-30 or SAE 30 motor oil. At engine operating temperatures these oils are the same. The only time the 5W-30 oil is "thin" is at cold start up conditions where you need it to be "thin."
So how do they get a motor oil to flow in the cold when it is a thicker viscosity at 210° F?
The addition of Pour Point Depressant additives (VI) keep the paraffin in petroleum base oils from coalescing together when temperature drops. Pour Point Depressants can keep an oil fluid in extreme cold temperatures, such as in the arctic regions. We will not go into Pour Point Depressing additives at this time except to say they are only used where temperatures are very extreme to keep the motor oil from becoming completely immobilized by the cold temperature extreme. For now we will just discuss the Viscosity Improvers (VI) additives.
Why don't we just use a SAE 10 motor oil so we can get instant lubrication on engine start up?
The reason is simple: it would be a SAE 10 motor oil at 210° F! The lower the viscosity, the more wear will inevitably occur. This is why it is best to use the proper oil viscosity recommended by the auto manufacturer as it will protect hot and at cold start ups. Obviously a 10W-10 motor oil won't have the film strength to prevent engine wear at full operating temperature like a 5W-20, 10W-30 or 5W-30 motor oil for example.
The VI additives have the effect of keeping the oil from thinning excessively when heated. The actual mechanics of this system are a little more complex in that these additives are added to a thinner oil so that it will be fluid at a cold temperature. The VI additives then prevent thinning as the oil is heated so that it now can pass the SAE viscosity rating at 210. For example; if you have a SAE 10 motor oil it will flow like a 10W at the colder temperature. But at 210 degrees it will be a SAE 10 giving us a 10W-10 or SAE 10 viscosity rating. Obviously this is good at cold start up, but terrible at engine operating temperature especially in warmer climates. But by adding the VI additives we can prevent the oil from thinning as it is heated to achieve higher viscosity numbers at 210 degrees. This is how they make a petroleum based motor oil function for the 10W-30 rating. The farther the temperature range, like with a 10W-40, then more VI additives are used. With me so far? Good, now for the bad news.
Drawbacks of Viscosity Improving additives
Multi-grade motor oils perform a great service not being too thick at cold startup to prevent engine wear by providing more instantaneous oil flow to critical engine parts. However, there is a draw back. These additives shear back in high heat or during high shear force operation and break down causing some sludging. What's worse is once the additive begins to be depleted the motor oil no long resists thinning so now you have a thinner motor oil at 210 degrees. Your 10W-30 motor oil can easily become a 10W-20 or even a SAE 10 (10W-10) motor oil. I don't have to tell you why that is bad. The more VI additives the worse the problem which is why auto manufacturers decided to steer car owners away from motor oils loaded with VI additives like the 10W-40 and 20W-50 viscosities.
The less change a motor oil has from high to low temperatures gives it a high Viscosity Index. Synthetic motor oils that are made from Group IV (4) PAO base stocks have Viscosity Indexes of more than 150 because they are manufactured to be a lubricant and don't have the paraffin that causes the thickening as they cool. But petroleum based motor oils (Group I (1) & II (2)) usually have Viscosity Indexes of less than 140 because they tend to thicken more at the colder temperature due to the paraffin despite the addition of Viscosity Improving additives. The higher the Viscosity Index number the less thinning and thickening the motor oil has. In other words, high number good, low number bad. Low numbers thicken more as they cool and thin more hot. You see these Viscosity Index ratings posted on data sheets of motor oils provided by the manufacturer.
As already mentioned, VI improving additives can shear back under pressure and high heat conditions leaving the motor oil unable to protect the engine properly under high heat conditions and cause sludging. Also there is a limit to how much viscosity improving additives can be added without affecting the rest of the motor oil's chemistry. Auto manufacturers have moved away from some motor oils that require a lot of viscosity improving additives, like the 10W-40 and 20W-50 motor oils, to blends that require less viscosity additives like the 5W-20, 5W-30 and 10W-30 motor oils. Because stress loads on multi viscosity motor oils can also cause thinning many racers choose to use a straight weight petroleum racing motor oil or a PAO based Synthetic which do not have the VI additives. But only the Group IV (4) PAO based synthetics don't need VI additives.
Source: http://www.upmpg.com/tech_articles/motoroil_viscosity/
« Reply #5 on: June 24, 2012, 06:51:09 AM »
Quite a read!
I wonder how many finished it to the bottom?  Did you?
« Reply #6 on: June 24, 2012, 11:00:18 AM »
I'm a bit old fashioned [ cuz I'm gittin' old] and its been quite a while since I did my college papers on oil.. But,, oil is still pretty the same,, almost..
I've never been a fan of mixing oils,, I don't believe in it and probably never will.. Especially when it comes to mixing 'regular' with 'synthetic'.. Since there still are only 2 basis synthetic oils,, I certainly wouldn't mix them.. Most 'regular' oils today are still of two types [ asphalt and paraffin] so I wouldn't recommend mixing them either even when it is stated they can be mixed..
All that said,, its probably still best to mix oils if needed than to run an engine without enough oil and then change it ASAP..
The above article is a good one and should solve some of the old wives tales about multi-grades..
Valker
Wahoo!!!!
Texas Panhandle
« Reply #7 on: June 24, 2012, 11:23:36 AM »
Quite a read!
Yes, I did. Not too sure what part you mean or are alluding to. If it's the part about racers using straight weight, you can do that when the engine will run at one temperature all the time.
I meant it to clear up what many folks allude to about "if you mix a 10 wt oil with a 20 wt, you have a 15 wt oil".
Tropic traveler
Silver Springs, Florida
« Reply #8 on: June 24, 2012, 11:32:00 AM »
5W40 Rotella T-6 for the last 50,000 miles. 1997 Tourer now with 113,000 miles of mostly hot Florida riding. Original clutch & doesn't use a drop of oil.
5W is just fine for your Valk.
'13 F6B red for Kim
