February 05, 2026, 08:10:55 AM *
Author Topic: Help  (Read 1994 times)
Shotgun
Canadian Lakes, Michigan
« on: June 24, 2012, 09:12:03 AM »
I have Speedbleeders on my Valk.  I just changed the brake fluid and everything went fine.  I went to change the clutch fluid and it didn't go so well.  I did it like I always do, open the Speedbleeder and gently pull the clutch lever pumping the old fluid out as I pour the new in.  I'm guessing I may have let the level get too low in the reservoir and got a little air in the line because the clutch handle has no resistance and the clutch doesn't work.  Before I do anything else, is there a simple way to solve this problem?  TIA
Slammer
Lafayette,La.
« Reply #1 on: June 24, 2012, 01:44:28 PM »
I had to break the banjo bolt at the master cylinder to get the air out there before I could get it to pressure up.
Shotgun
« Reply #2 on: June 24, 2012, 01:47:18 PM »
After further inspection, what I thought was a Speedbleeder was not.  I thought I had one in but it is just a regular bleeder so I'm sure there is air in there.  I have a Speedbleeder that I would like to use.  If I put in in, what can I do to get the system filled with fluid?
« Reply #3 on: June 24, 2012, 02:41:42 PM »
You're better off buying a Mity Vac at an auto parts store. Another option is to use a turkey baster to push fluid up  from the bleeder back to the master cylinder.
N8171S
Marlboro, Mass
« Reply #4 on: June 24, 2012, 03:40:14 PM »
We always filled the brake cylinders on aircraft from the bottom up.  Get a trigger oil can dedicated to just brake fluid, fill it up and pump the fluid in at the bleeder.  Works much better than a turkey baster. Turkey basters are for turkeys.  Keep an eye on the level so you don't overflow it.
Shotgun
« Reply #5 on: June 24, 2012, 05:25:05 PM »
Thanks for the advice.  Just put some tubing over the the end of the trigger can and the other end over the bleeder?
9Ball
« Reply #6 on: June 25, 2012, 07:13:13 AM »
you can use a veterinary syringe and surgical tubing too.  Just bleed all the bubbles from the tubing then attach it to the nipple and crack the bleeder slightly.  Force the fluid and bubbles up into the master cylinder....
WARNING...make sure there is room to accept the volume of fluid you are adding otherwise you will overflow the master cylinder....
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
JaysGone
Delray Beach Florida
« Reply #7 on: June 26, 2012, 02:41:38 AM »
http://www.harborfreight.com/brake-bleeder-and-vacuum-pump-kit-69328.html
Best money spent for bleeding brakes and clutch.
Makes doing the whole bike a 30 minute or less job.
      1999 Valk - SOLD
      2005 Yamaha RoadStar
Thunderbolt
Worthington Springs FL.
« Reply #8 on: June 26, 2012, 02:49:42 AM »
Ty-wrap the clutch lever to the bar overnight, seems to help get the air out.
« Reply #9 on: June 26, 2012, 03:29:35 PM »
This is the unit I now use. Works great for home duty use.
http://www.harborfreight.com/brake-fluid-bleeder-92924.html
Shotgun
« Reply #10 on: June 27, 2012, 03:33:04 AM »
Thanks again.  I got it handled.  All is well but I can't get the reservoir all the way full because of the angle it is on, even with the bars turned all the way to the right.
JaysGone
« Reply #11 on: June 27, 2012, 03:40:47 AM »
You do after all have to loosen up the handle bars at the clamps a bit sometimes.
Just a bit to get the angle right to fully refill.
      1999 Valk - SOLD
9Ball
« Reply #12 on: June 27, 2012, 03:43:16 AM »
It doesn't have to be all the way full, but you can loosen the two bolts and on the face of the master cylinder clamp and rotate the entire assembly to get a better angle for filling....just make sure to tighten securely so that this doesn't come loose on you and cause a much worse problem while riding down the road...
1999 Standard
2007 Rocket 3
2005 VTX 1300S
heavyd
« Reply #13 on: June 27, 2012, 10:01:49 PM »
I had the same angle issue when I was bleeding my front brakes. I had it up on my jack so the bike was held vertical, I had to wait until I had it back on the side stand to fill it. Loosening the clamp let me level it front to back, but not side to side.
