November 24, 2025, 01:52:19 PM *
Author Topic: Electrical Connection turn signal kit  (Read 1129 times)
Firefighter
Harlingen, Texas
« on: June 24, 2012, 10:37:32 AM »
I saw in the forums about the Electrical Connection turn signal conversion kit. I looked it up and it is supposed to fit my interstate. I am trying to install today. First my interstate has no brake wire at the turn signal area so I had to run one. Now I have the turn signals all apart and see no way of running the new wires through the stem to the light socket area. Anyone done this on a interstate? Thanks for any help!
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
john
tyler texas
« Reply #1 on: June 24, 2012, 10:53:05 AM »
look at (search) bigbf.com website ...
find within ...
how to install  Electrical Connection turn signal kit                               cooldude
vrcc # 19002
NITRO
Eau Claire, WI
« Reply #2 on: June 24, 2012, 01:08:07 PM »
Good luck, getting the wires through the stems is a total PITA. I ended up guiding kind through with a bamboo skewers.
« Last Edit: June 24, 2012, 05:27:57 PM by NITRO » Logged
When in doubt, ride.
« Reply #3 on: June 24, 2012, 02:32:33 PM »
I didn't know the I/S and the standards/tourers where different.  I just stuck the wires in there and ran them through there.
Firefighter
Harlingen, Texas
« Reply #4 on: June 24, 2012, 04:48:17 PM »
The only difference  between IS and standard  is no tail light wire at the turn signal light assy. I finally figured out how to get the light socket out and then fished the wires through. I spent a couple of hours getting a brake wire to the right location. My trouble now is sticking the LED light ring to the inside lens. Thought I had it siliconed , dried for several hours only to come loose when I tried to attach the wires. Have siliconed it again now sitting, drying with a little weight holding it in place. Will let it dry longer then try again.  Thanks
1978 Honda 750
Thunderbolt
Worthington Springs FL.
« Reply #5 on: June 24, 2012, 05:48:30 PM »
If you don't get them to stick, Electrical Connections makes a different setup, don't remember the number, but it has a rubber grommet that the light slides through and fits tightly on the bulb.
PhredValk
Edmonton, Alberta, Canada
« Reply #6 on: June 24, 2012, 07:57:00 PM »
I did mine this spring, 99 IS. You have to take them as apart as you can, and run a wire from the signal pods to the middle, bend it, and pull the wires in from that side. The brake wire you have to run all the way to the right side panel.
Fred.
VRCCDS0237
