February 05, 2026, 08:11:01 AM *
Author Topic: VOLTMETER  (Read 1359 times)
pocobubba
Pocomoke , Md
« on: June 25, 2012, 02:22:35 PM »
I'm going to install a voltmeter on my standard , where is the best place to pick the wiring , in the headlight or at the battery ?
Thunderbolt
Worthington Springs FL.
« Reply #1 on: June 25, 2012, 03:19:15 PM »
You will get the best or truest reading closer to the battery on a wire dedicated to the meter.  I would put a fuse in line where you attach the wiring wherever you mount the meter just in case the wiring gets shorted to ground.
pocobubba
Pocomoke , Md
« Reply #2 on: June 25, 2012, 03:22:39 PM »
Thanks Thunderbolt , I'll pick it up on the battery .
Thunderbolt
« Reply #3 on: June 25, 2012, 04:56:01 PM »
After reading my response, maybe I should have mentioned that the fuse needs to be installed as close to the battery as possible.
Grandpot
Fort Mill, South Carolina
« Reply #4 on: June 25, 2012, 05:00:17 PM »
Make sure you put it on a circuit that is off when the key is off.
vanagon40
Greenwood, IN
« Reply #5 on: June 25, 2012, 06:09:25 PM »
I used the fused hot wire (my addition) that runs directly from my battery to my aftermarket horn.  I added a relay connected to the auxiliary connection under the right side cover so the meter is on/off with the key.
The best reading will come directly (or as close as possible) from the battery, with no voltage drops for lights, radio, etc.
« Reply #6 on: June 26, 2012, 04:39:09 AM »
+1 on connecting direct to the battery.  Now the battery is not switched off with the key but I made that work for me.
After I got my Volt meter mounted up and ran a fused hot lead to the battery and a ground line.  I put a switch mounted at the left neck cover panel (plastic cover) that was inline for the ground lead.  Now I can turn the Volt meter off by that switch.  What is helpful is, I can turn it on without starting the bike...this shows me how the battery is holding a charge (usually right at or just under 13V)
Then when I start her up the needle climbs to 14V and I know all is well
This was taken engine off Volt meter on
This was taken engine running
« Last Edit: June 26, 2012, 05:18:08 AM by Chrisj CMA » Logged
