March 09, 2026, 05:16:28 PM *
Author Topic: Has anyone built a saddle out of Memory Foam?  (Read 1393 times)
Jabba
VRCCDS0197
Greenwood Indiana
« on: May 31, 2009, 06:10:28 AM »
I have a tempur pedic bed and LOVE it.
I have been thinking about getting a stock seat from someone... and cutting it up and building a custom saddle out of the memory foam.
I can't be the 1st to think of this.
Anyone have any experience here?
Jabba
« Reply #1 on: May 31, 2009, 06:14:20 AM »
Could this guy help you?
He has a great reputation.
http://greatdaytoride.com/Home_Page.php
wd40
Winnemucca, NV, Reno NV
« Reply #2 on: May 31, 2009, 06:37:15 AM »
I think the key to a great saddle is variable density foam.  Softer in the center, firmer at edges.  This keeps pressure from creating those uncomfortable hot spots, esp at the tailbone, and supports the cheeks properly.  I've seen lots of mod ideas online, including placing a foam insert in the original saddle to cutting out s portion of the seat pan to reduce support in the tailbone area.  My wife and I both got custom saddles from Rick Mayer.
http://www.rickmayercycle.com/
On the left of the linked page he has a page about foam.  On that page, he states "My opinion is that a comfortable motorcycle seat is 90% fit and 10% foam. Really, a well fit seat can be constructed from solid steel and be relatively comfortable."  After riding on a custom saddle, and some extremely pathetic factory ones I have to agree.  It's gotta fit YOU, or it doesn't matter what it's made of.  Good luck with your project!!
F-106
« Reply #3 on: May 31, 2009, 08:46:20 AM »
Don't wast your time. the trick to seats is how wide the seat is and thickness to your weight. A good rule is 1" wider than you hips on both sides. A flat seat seems to work good on the valk due to your legs are under you .A back rest also is helpful
