February 05, 2026, 08:11:08 AM *
Author Topic: front brake leaking fluid  (Read 1129 times)
bill martin
« on: June 29, 2012, 04:19:58 PM »
what to check?
F6BANGER
Albuquerque NM
« Reply #1 on: June 29, 2012, 05:17:44 PM »
Where is it leaking from? Caliper? Brake line? Banjo bolt? Reservoir?
Are you sure its not your fork seal? Probably the right side? Its common.
F6MoRider
Lakeland, FL
« Reply #2 on: June 29, 2012, 07:31:51 PM »
+1 on the check and find the source.  Mine was the right folk seal leaking but looked like the brake.
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
bill martin
« Reply #3 on: June 30, 2012, 03:42:34 PM »
Thanks to all.
The fluid was dripping off the caliper onto the ground, but now that I think about it, the fluid seemed more like oil than brake fluid.  You are probably right about it being the fork seal.
