February 05, 2026, 08:10:26 AM
Alternator - bolts - nevermind
Topic: Alternator - bolts - nevermind (Read 1353 times)
sheets
Jct Rte 299 & 96, Calif.
June 30, 2012, 12:09:54 PM »
A week or so ago, at the recommendation of somebody here, I cracked'em loose -- removed them, put some
anti-seize
on them and put them back in. Those guys were really glued in. Took a few minutes of gentle persuasion on each one to break each one free.
Found it . . . 12mm
Last Edit: June 30, 2012, 12:37:27 PM by sheets
Fritz The Cat
Re: Alternator - bolts - nevermind
June 30, 2012, 01:34:51 PM »
Are we talking factory tight here or do they over tighten on there own?
sheets
June 30, 2012, 01:46:11 PM »
I'm assuming factory tight. But after thirteen years, who knows. Ran the motor for a few minutes just to warm things up a bit. If ya snapped one off, I don't know how you'd ever get it out. They are "schmooied" (in "Ratdog" speak) up perty good now so they will come out with little effort in the future.
Yrmv,
Last Edit: June 30, 2012, 04:30:46 PM by sheets
Fritz The Cat
June 30, 2012, 02:36:22 PM »
Think I'll use an air wrench when I get to that point. It sorta vibrates bolts off.
tank_post142
south florida
June 30, 2012, 02:50:25 PM »
like the man said: heat that motor up. dissimilar metal corrosion will bind them in there tight.
I got a rock
VRCCDS0246
Whooray
Idaho State Rep
Kuna, Idaho
July 01, 2012, 12:03:43 PM »
I had trouble getting them out also. I have been able to remove two of them and apply anti seize but one is still in there and giving me fits. I have been working on it for some time now. gently turning it out until it wont go anymore then screwing it back in. Back and forth little by little hoping that it will come all the way out eventually. Scared to death that if I apply too much trying to get out that it will snap. Raymond
Vietnam Vet 6/68 - 1/70
919th Combat Engineers
11th ACR (Blackhorse)
YoungPUP
Valparaiso, In
Reply #6 on:
July 01, 2012, 05:54:37 PM »
Patience with a hand wrench. Air wrench=lots of bad language.
99 STD (Under construction)
