February 05, 2026, 08:11:04 AM *
Author Topic: *@%* SCrew  (Read 1486 times)
BarendR
« on: July 01, 2012, 10:43:29 AM »
I've been trying to get the screw under the trunk latch of my I/S out, the sumbich ain't moving!  Tried  the regular screw driver, didn't work.  Tried heating the nut beforehand, didn't work.  Tried grinding a bigger slot in the head so i could get a BMF screwdriver in there, no luck.  Tried grinding the sides of the screw down so I could get a wrench on there, didn't work either.  Seems like that thing is welded in there   tickedoff tickedofftickedoff
So how do I get this POS out of there short of grinding the whole head down?
Barend
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #1 on: July 01, 2012, 03:40:07 PM »
Take a pic and post it here - I think I know which screw you're talking about, and it may be the one that caused me grief, but not quite sure.
YoungPUP
Valparaiso, In
« Reply #2 on: July 01, 2012, 06:07:04 PM »
Try heating the nut and as soon as you remove the heat apply a birthday candle or crayon to the edge where the nut meets the threads.  Remove as planned.
99 STD (Under construction)
« Reply #3 on: July 02, 2012, 07:04:40 AM »
CAREFUL,,, you can melt the plastic!
« Reply #4 on: July 02, 2012, 12:19:53 PM »
One of those impact nut (screw) drivers.
