April 01, 2026, 04:42:57 PM *
Author Topic: found a really cool product today  (Read 1295 times)
Clark
« on: July 01, 2012, 07:57:25 PM »
got a call from a friend who manages a large multi million dollar ranch here in the sun valley area.. the owner who has waaay too much money is old and his health is failing.. sooo this may be his last time he makes it to the ranch..soo what was needed was a wheel chair ramp that went up the 4 steps into his bedroom.. the owners daughters words were "tell him I dont care what it costs we need it done today.. so off to the shop.. welded up a tube frame and covered it with a sheet of 3/4 AC plywood. but heres where the cool product come in.. I bought a qt. of solid body stain as it needs no primer and found a jar of ground up walnut shells that is made to mix with pain and creates GREAT TRACTION.. had used sand before but this stuff is THE BOMB.. would be great for trailer decks or boat decks too.. if ya need some traction..check it out.. forgot to mention his mode of transport is a Gulfstream IV... NOW what to charge?? hmmmmm
« Reply #1 on: July 01, 2012, 08:20:54 PM »
1.2 mil and i'll ONLY ask fer $300000.00. cooldude And yer still WAY ahead. 2funny RIDE SAFE.
sugerbear
wentzville mo
« Reply #2 on: July 01, 2012, 09:06:35 PM »
THANKS.  will be building a ramp for our son soon, into our house.
Clark
« Reply #3 on: July 01, 2012, 09:13:57 PM »
a buddy just told me they are using this same product  in place of sand for blasting paint off.. seems the sand dust is carcinigenic and the shells work GREAT
sugerbear
wentzville mo
« Reply #4 on: July 02, 2012, 11:42:48 AM »
i've heard of using shells in tumblers but not blasting.
tank_post142
south florida
« Reply #5 on: July 02, 2012, 12:24:35 PM »
works great in a tumbler, i just run down to the local pet store and pick u a bag(birdcage liner)
I got a rock Sad
VRCCDS0246
Master Blaster
Deridder, Louisiana
« Reply #6 on: July 02, 2012, 12:49:43 PM »
Also used extensively for cleaning the blades on turbine engines.
mrprez
Mobile, AL
« Reply #7 on: July 02, 2012, 01:00:15 PM »
Healthcare related so you should get your asking price and then some.
Madmike
Campbell River BC, Canada
« Reply #8 on: July 02, 2012, 07:20:48 PM »
Ive heard that you have to be aware of any allergies if you use this as a blasting media.... IMHO some of the problems using sand are abrasion and you can stretch the metal and cause wrinkles, the walnut is softer and less likely to cause problems.  Someone better versed in metal prep and repair could add lots of better info.
« Reply #9 on: July 03, 2012, 05:16:23 AM »
The blaster we use, uses plastic pieces.    He used to use walnut shells, but like the plastic stuff better.
I'm just relaying on what he has said, so don't kill the messenger.
