February 05, 2026, 08:11:29 AM *
Author Topic: clutch switch ?  (Read 1136 times)
valku2
« on: July 03, 2012, 05:17:47 PM »
Does the clutch switch physically wear out?  More specifically, the little pin that comes out of the switch does go in and out, but the clutch lever does not reach the little pin when you pull the lever in. The action of the lever does not feel right, kinda stiff, like non-hydraulic.  Bike has almost 83K on it and all fluids were changed about 2K ago.  TIA.
1999 Pearl Orange/Black Valk Std. (currently in tourer mode) SOLD IT
2004 CBC Rune - bone stock - SOLD IT
2014 Red, Yellow and Black Honda GROM - stock
2018 Electric Blue HD Softail Deluxe
tank_post142
south florida
« Reply #1 on: July 03, 2012, 05:36:16 PM »
switch can wear the contact point on the lever can wear, but more likely the pivot bushing in the lever has worn.
I got a rock Sad
VRCCDS0246
valku2
« Reply #2 on: July 03, 2012, 05:45:39 PM »
Thanks for the idea(s).  I have replaced the bushing since the fluid change.  Felt good for less than 200 miles.  Now, not a good feeling at all.
« Reply #3 on: July 03, 2012, 07:12:04 PM »
Remove the pivot bolt and clean and relube the bushing/bolt with a waterproof bearing grease. It's one of those annual things I do. A new brass bushing might be needed.
john
tyler texas
« Reply #4 on: July 03, 2012, 07:58:52 PM »
                        coolsmiley                        graphite
vrcc # 19002
« Reply #5 on: July 04, 2012, 08:10:13 AM »
Yep, when all the talk about maintenance abounds, there is very little about maintenance of the handlebar levers.
A drop or two of oil every once in a while does a lot to protect these things.
It's especially a good thing if you ride in rain. They are exposed to a large extent to all the bad things.
You can easily check the operation of the switch with a continuity test.
A new stock lever is cheap and is guaranteed to fit and work properly. No modification necessary as so many of the aftermarket levers require.
A little oil is the first and foremost preventive maintenance practice.
valku2
« Reply #6 on: July 05, 2012, 01:58:28 PM »
Thanks again for the helpful notes.  I took the handle, pivot rod, bushing and little push rod apart and cleaned them up.  Lightly re-oiled all parts and reassembled.  It works better, but still leaves me thinking something is soon to fail in there after 83K miles.   So I'm ordering all those little parts (including the clutch switch) and changing them out.  For further reference; I also came across this, from another bonafide Valkoholic....
http://lifeisaroad.com/clutchlever.html
Thanks Daniel.
