April 30, 2026, 12:45:43 PM *
Author Topic: been workin on the Black and Silver...  (Read 1582 times)
hotglue #43
« on: July 03, 2012, 10:07:12 PM »
Some backfires in the mountains on decel.., and the #3 cyl is turning the pipe blue....
  Replaced the intake orings,\... they were more like gaskets... pretty flat.     De-smogged the bike...  changed the plugs and wires...   did a little painting....  and started putting it back together.....  New vac line from #6 to the petcock...All the rest of the vac lines are plugged and isolated.... if that doesn't fix the starving fuel... I'll pull the petcock valve and eliminate the last of the vac lines.....
  Next I need to sync the carbs....  The Texas group has a sync tool thanks to Dag...  I need to find out where it is...
 blue=3 times
 green=at least 4 times
« Reply #1 on: July 04, 2012, 04:57:50 AM »
Contact Rocketman.  I believe he has the sync gauge briefcase.
Hay Cool
