August 17, 2025, 07:24:55 AM *
Author Topic: Blowing fuses on added circuit ?  (Read 1191 times)
whitestroke
San Pedro, Ca.
« on: July 05, 2012, 07:32:58 PM »
The PO installed these auxillery running lights(see link).  They were tapped in to the Blue headlight wire in the headlight bucket.  The 10amp. headlight fuse blew.  I looked up this problem and saw in shoptalk I needed to add a new headlight circuit with relay, or risk burning up the starter switch.
I added the new circuit and have the auxillery running lights and headlight on this new circuit.  The new circuit has a 15amp. fuse and it has blown twice.
Do I increase fuse to 20amps. ?
Are H.F. fuses p.o.s. ?
I'm not sure what size fuse to run.
http://www.cruisercustomizing.com/kuryakyn-small-halogen-silver-bullets-w-38-in-16-hollow-mounting-bolt-pair-clear-lens/part/KY-2305
« Last Edit: July 05, 2012, 07:46:02 PM by whitestroke » Logged
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
Michvalk
Remus, Mi
« Reply #1 on: July 05, 2012, 08:02:46 PM »
First thing I would do , is go over the wiring to make double sure there are no pinched wires, or cuts in the wiring. Did you use a wiring diagram from the board to follow? Make sure you have all the wiring correct. I am not sure of the requirements for fuze size for those lights. Maybe someone familiar with these lights will chime in, but, I would think 15 amps would run them. That's why I suggest going over the install again, just to make sure.  cooldude
whitestroke
San Pedro, Ca.
« Reply #2 on: July 05, 2012, 10:19:30 PM »
P.S.
Fuse hasn't blown the last 2 days of riding. ...
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
Blackduck
West Australia
« Reply #3 on: July 05, 2012, 11:14:02 PM »
Depends on what wattage the lights are. Watts divided by voltage will give you amperage.
IE, 100 watts divided by 12 volts = 8.33 amps  ( 100 W / 13.5 V= 7.41V)
Added another amp to the total to allow for any loss in wiring etc and you will have the minimum fuse size required.
So if your lights are 100 W you would need around a 20 amp fuse (2 x 100= 17.66 amps plus 1 = 18.6 Amps minimum)
Remember you need a good earth/ground return as this can cause the same sort of problems.
Personally for driving lights I run a ground wire back to the battery
Cheers Steve
« Reply #4 on: July 06, 2012, 11:03:06 AM »
60W headlight 20Wx2 Aux lights = 100W
100W / 12V = 8.3A
8.3A x 1.2 = 10A fuse
If you're repeatedly blowing 15A fuses, something is wrong.
whitestroke
San Pedro, Ca.
« Reply #5 on: July 06, 2012, 04:02:32 PM »
If the headlight is 60/55w is that 60+55 with highbeam on.    Undecided
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
« Reply #6 on: July 06, 2012, 08:16:50 PM »
On a dual filament headlight bulb, only one filament is supposed to be hot at a time.  Because dimmer switches are make-before-break, it is possible to hold the switch in a position between high and low and have both filaments lit, but I'm sure that isn't good for the life of the bulb.
whitestroke
San Pedro, Ca.
« Reply #7 on: July 06, 2012, 08:27:35 PM »
OR THE FUSE
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
whitestroke
San Pedro, Ca.
« Reply #8 on: July 06, 2012, 10:12:48 PM »
The only ground wire I ran was from the relay to the Headlight bucket ground screw.
Is this enough?
There is the original ground wire also.
« Last Edit: July 07, 2012, 11:19:18 AM by whitestroke » Logged
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
