August 17, 2025, 07:24:48 AM
Rear Wheel Maint
Topic: Rear Wheel Maint (Read 1257 times)
greggh
OMAHA NE
Rear Wheel Maint
July 06, 2012, 02:53:14 PM »
1998 Black Standard, 76,689 miles.
With all the talk about rear wheel dampers and final drives. I though I should have a look after 3,500 miles.
I would post pics but the photostash won’t let me in with my user & pass, the same as the VRCC user and pass right? Any ideas?
Anyway,
Splines look great and Gary’s dampers of 3 years and 38K are holding strong.
Do need to replace the shock bushings though, not terribly bad yet but they are showing wear.
Have I read on here that the VTX shock bushings are a sufficiant replacement?
If so how which VTX models would I look under and where?
Safe travels Greggh
justintyper
syracuse,ny
Re: Rear Wheel Maint
July 06, 2012, 03:18:49 PM »
the part number you are looking for is for the vtx1800 not sure the year part number is 52489-HN0-671 and i ordered trhem from my local honda dealer for 2.45 a piece
donaldcc
Palm Desert, CA
July 06, 2012, 03:38:52 PM »
Quote from: greggh on July 06, 2012, 02:53:14 PM
I would post pics but the photostash won’t let me in with my user & pass, the same as the VRCC user and pass right? Any ideas? . . .
yeh, skip photostash and go to photobucket.com
Don
greggh
OMAHA NE
July 08, 2012, 01:17:22 PM »
Hey sorry for the delay in getting back to you two.
Thanks for the part numbers on the Shock bushings.
Too k the photobucket advise and I hope this link takes you to the pictures.
http://s1250.photobucket.com/albums/hh526/greggh1228/
donaldcc
Palm Desert, CA
July 08, 2012, 03:14:46 PM »
gregg on photobucket move your cursor over your uploaded pic and then click on "IMG Code" at the bottom and it will copy the link to your pic and then you can just paste it into your post. You can post a smaller version of your pics to photobucket if it is too large.
like this
Last Edit: July 08, 2012, 03:16:26 PM by donaldcc
Don
greggh
OMAHA NE
July 08, 2012, 04:42:20 PM »
that's very sweet.
will do thank you
=> InZane XXV
